Maybe we can make this Sticky?? Have a comparison against other GTR's with mods or in stock form.
Got my car dyno'd today, after fitting the PFC & Cam Gears, here's the result & my list of mods.
MODS: GTR Series 3 98model
Power FC & Hand Controller
Cam Gears (Settings +4 & -6)
Stock Turbos (14psi ~<1bar)
Turbosmart bleed valve
Exhaust - stock dumps, 2.5 front pipe into 3inch, stock Cat, 3" from cat back
HKS Pods (No CAI)
Total 249.1kw @ ALL FOUR WHEELS
Thanks to:
1. boys at ICE for help & advice
2. Merli from SAU for letting me know it's kw@all four wheels, & not rwkw.
https://www.sau.com.au/forums/topic/30410-gtr-dyno-results/
'95 Series 1 GTR
  • Apexi Front pipe, 3" Cat, 3.5" Catback
  • Standard turbos and 'cooler
  • Boost @ 1.0 bar (Blitz Dual SBC)
  • Power FC
  • HKS pods
234.8kw at the rears
So, theoretically, with cam gears i should get a 15kw increase.. that sounds about right.
https://www.sau.com.au/forums/topic/30410-gtr-dyno-results/#findComment-616575
If you think these figures are overinflated, that's because they were done in RWD...
If the driveshafts were left in and the cars dyno'ed on a 4WD dyno, they would read about 20kw lower.
https://www.sau.com.au/forums/topic/30410-gtr-dyno-results/#findComment-616584
mine made 210kw at all 4 with same mods.
https://www.sau.com.au/forums/topic/30410-gtr-dyno-results/#findComment-616593
But a GTR is in rwd mod until traction is loss so in the real world that figure is probably correct, unless of course your doing 8K luanches :D
https://www.sau.com.au/forums/topic/30410-gtr-dyno-results/#findComment-616664
that seems a bit high for stock turbos!
u should have used ben at race paces dyno it gives much more realistic dyno readings
Hi INASNT,
They're stock as they come.. The car will be at ICE later this week or next. I'm getting the HKS EVC IV fitted, & need new spark plugs.
Hi Merli,
The dyno was done in 4WD!! "shootout mode, I think??".. not 2WD. It was done at Subaru Docklands, in Victoria. In fact it hit around 265rwkw, but that's when we dropped the boost back.
Intersting my PFC Hand Controller, shows my knock levels to average around the 13mark, max I hit was 21... is this OK?
Thanks
meshmesh
https://www.sau.com.au/forums/topic/30410-gtr-dyno-results/#findComment-616755
But a GTR is in rwd mod until traction is loss so in the real world that figure is probably correct, unless of course your doing 8K luanches ;)
Yup... absolutely true...
That's why a GTR that spins up 250kw @ wheels will be faster than another RWD car that spins up 250kw @ wheels...
Because when you actually take them to the road, the GTR is making more than 250kw @ wheels :) :) :D :D
https://www.sau.com.au/forums/topic/30410-gtr-dyno-results/#findComment-616815
Sorry mate, you said in your first post (and this one): 249rwkw, which means "249 rear wheel kilowatts"... Got GTRs dyno'ed on an 4WD dyno, we usually say "249 kw @ all four" so we can differentiate ;) Hope that helps!
Excellent power figures for those mods! I think we all need to get some cam gears for our GTRs soon too! Did they make a big difference in spool up time as well as a good power increase?
Oh, and great choice on boost controller! Let us know how it goes and how it compares to the bleed valve!
https://www.sau.com.au/forums/topic/30410-gtr-dyno-results/#findComment-616823
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
