I got a set of gtr doors at home, 32kg, they still have most of the bits inside. minus the outer interior skins/trims
you could easily get them down to 20 something by removing motors and adding winders or something and cutting a bit
you cant just say that you can do that. im not trying to sound like a prick but ive done all the cutting and shutting that was worth while and removed the window glass and motors and it doesnt add up to 12kg. i weighted it every step of the way and if i had a search im sure i could find the paper work for it and it goes no where near 12kg.
im all for people having a go at trying it but its like me saying cut 3 inches off each end of the chassis and youll save 100kg. ive never done it so i dont say it can be done especially when some one is asking for facts and figures from what people have had proven results from.
the proven results were written in the post above yours.
regardless of that it sounds like you have the light weight doors so some one should buy them.
im not trying to be a natzi i just get anoyed when people say it can be done because they heard from a friend of a friend that read it on the internet which was probably wrong to start with. i very rarely enter into topics like this unless ive done it because i had spreading hear say.
  • Replies 72
Posted Images
32kg is exact same is late model gtst doors (which i have)
ok one more question...
what years did the early doors end and the heavy doors start??
i just saw some 92' doors and found out they are the heavy f%^kers.
so what...light - 89-91 and heavy - 92-93??
Yew, i wasnt saying 20kg on the nose. but 20 something.. you'd be spending a bit on lexan and grinder discs.. (also i wasnt sure if i checked if they were side intrusion jobs too)
p.s. i didnt see your post either ;)
short answer: yes it can be done
watch some video-option where they do the SUPER-LAPS they have some impressive figures for their track r32
remove all your glass windows and replace with Lexen/Perspects
remove anything that isn't needed (air con, cd player + speakers, redo wiring harness, washer bottles), cut up the doors and any other panels which will not affect the strength/stiffness of the car.
also not sure if you can/allowed use aluminum parts (e.g from gtr guards and bonnet), fiberglass or carbon seats etc
Edited by Kaido_RR
just to clear up some stuff about the doors.
yes the early model R32 (both GTR and GTST) do not have side intrusion bars in them from the factory. HOWEVER most of the cars that have been imported would have had the intrusion bars fitted during compliance (which them makes them just as heavy give or take than the late model doors).
BUT, early model doors with aftermarket intrusion bars fitted CAN have the bars removed (they are usually riveted and welded in place).
the early doors are 89,90 and part of 91. late model intrusion bar doors start during 91 and of course run to 94.
the late model doors it's nearly impossible to remove the intrusion bar from. it's not really a bar at all. more of a giant plate of steel. and it's heavy as fark.
the only option really is importing a set of early model doors from japan (so you can be sure they haven't had intrusion bars added). i'd say about 80% of the early model cars in aus were complied properly and have had the aftermarket intrusion bars added to them.
to sum up:
if you have late model doors: forget about removing the intrusion bars.
if you have early model doors check if you have or don't have aftermarket bars in there. if you do have them they 'can' be removed but it's still not necessarily easy depending on which bar kit was used, and how they were installed.
you also need to consider the safety aspect. the intrusion bars were introduced for a reason. and they were retrofitted during compliance for a reason too. it's to stop you from getting turned into a vegetable if you are unfortunate enough to get t-boned. if you have an extensive cage that has side impact protection then it's not such a concern, but if you have no cage, or a basic cage without proper side intrusion protection then I personally would leave the bars where they are.
my 32 is a 89 model. it was registered in qld. has no intrusion bars in the doors. partly why i ran the cross brace on the driver side of the cage. I have seen some glass doors floating around, but the doors are light once you pull everything out of them.
there is considerable weight difference in the alluminium bonnet. it is a must.
remove all the bumper bar supports etc.
i removd the entire parcel tray and sheeted it with 0.9mm alluminium. same with door trims. no roof lining, glove box, dash cluster, nothing.
no power steer, no intercoolers, no wastegates, no turbos, no pipework, nothing.
no cast iron engine block lol......you get the picture.
1193kg
my gutted 32gtst weighs in at 1136kg full fluids etc
newer doors can have side intruisons removed by drilling spot welds & cutting intrusion in half 18kg weight loss just intrusion bars alone
i think the boys were refering to real race cars lol......no seriously Jas thats a great effort to get her that skinny. :P
i think the boys were refering to real race cars lol......no seriously Jas thats a great effort to get her that skinny. :banana:
Real race cars??? didnt you fit a commodore engine???
But also on a serious note the car has been built so it can be switched to circuit at any time
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
