hi all
i recently swapped out my motor and bolted up a new turbo etc to go with, ecu, dyno tune etc etc. problem is, the car seems to lack midrange power. it makes plenty above 5000rpm, which is nice, but the turbo should really be making its power from 3500rpm.
R33 RB25DET standard
gcg hi-flow turbo
480cc injectors + pump
fmic
greddy copy plenum
3in split dump + gutted cat
3.5in cat back
ebc
splitfire coilpacks
ems stinger ecu with map sensor
my run is the highest blue line without dots. i plotted two lines (with dots) above that to show comparisons from other RB25s who are also running gcg hi-flows at 16-18psi.
as you can see, theyre making 25-40kw more than me in the midrange, but almost identical peak power. this is very irritating since the whole reason i chose that turbo was so the car would be more responsive!
im at a bit of a loss as to how i could be losing this power, so ill outline some possible weaknesses of my setup.
-ems stinger ecu. running batch injection and waste spark. i realise this is not perfect, but all the information ive read tells me this shouldnt be a major problem.
-small throttle. the intake piping to the throttle is 3in, but the factory throttle is only 2.5in. would this be a big restriction? doesnt seem to affect peak power...
-soft wastegate. with the ebc off, boost only gets up to about 10psi. but with the ebc on the dyno the car makes 18psi at 3600rpm so i doubt this is a problem.
-pod filter sucking engine bay air. im going to get some cold air into that soon.
-boost leaks. theres a few small ones i am aware of so im in the process of replacing silicone joints etc. despite making 18psi at 3600rpm, if small leaks force the turbo to work harder in the midrange, will keeping the wastegate closed longer restrict exhaust flow/power?
should i ask them to have another go at tuning it?
https://www.sau.com.au/forums/topic/304604-wheres-my-midrange/
If you want more midrange for your setup i would get an adjustable cam gear. Does help a lot. Also an illegal way of gaining midrange power is removing the cat.
Without a cat my car makes 30rwkw more in the midrange!
*edit: just saw you have a gutted cat, replace it with a straight pipe with the cat shell welded on top.
Ok first of all you are right, that midrange for a GCG highflow is shit house, so you are correct that you need to find what is wrong.
Boost is coming on and holding fairly well, so it aint a boost/wastegate issue.
The thorttle aint the issue at all so don't worry about that.
And the pod sucking in hot ait also aint the problem so don't worry about that.
Have you ever had the timing belt off and replaced? If so are you sure the cams are dialled in correctly?
What piping do you have from the pod filter to the turbo? It aint sucking shut is it?
Edited by PM-R33
EMS makes me think there is a VCT issue, also tune could be a BIG thing.
my money is on the combination of both, so realistically its all tune related.. maybe put the stock ecu back in and have the EMS piggy back (to retain VCT etc)
random points, no particular order.
1. Tune, given the graph isn't all that smooth i wouldn't be surprised if it had a fair bit to do with it
2. Cam timing/belt could be off. Is VCT working?
3. Intake piping sucking shut
4. Cooler? What type?
5. You said boost leaks. If you are seeing 18psi @ the plenum AFTER boost leaks, you'll be making who knows what @ the turbo (eg 24psi). This could well be heating the air far to much.
6. Stock throttle body can flow 350rwkw+, so that's not a problem.
7. Drop the exhaust from before the CAT, just to see what happens (before/after dyno run)
8. You do need a better actuator. Personally i would be getting a 1bar/14psi actuator on there at some point.
1. post up your timing map, looks like there's crap all timing at low rpm
2. post up your A/F graph
I recommend adding more gain to your EBC @ 12PSI, the boost at 16PSI looks pretty good
R31Nismoid, don't think the intake pipe is sucking shut, you wouldn't get full boost all the way on the rev range.
I was thinking the VCT could be the issue aswell but it seems to be ok up until about 3500rpm, i would expect with the VCT not working at all that there would be a substantial power drop below 3500 aswell. Do EMS ecu's control VCT?
saying if it doesn't the power shouldn't look that bad.. I believe the tuner hasn't been bothered to tune the low/mid parts of the map..
Post up:
1. your timing map
2. your torque curve vs power/boost
off topic question, but can i ask, why did you upgrade the injectors to 480cc injectors? As far as i understand, standard ones are good for 230-40kw arent they? Or is that future mod, for more kw? just curious
they were on the plenum/fuel rail when i bought it second hand. also, yeah just a good upgrade to have up my sleeve.
thanks for your input.
yes the timing belt and head gasket were replaced when i put this motor in. so thats a very good point, i will have to ask my tuner about that.
the suction pipe is the factory one, clamped onto a z32 afm which is not wired up since im using a map sensor.
Also interested to see the answer to this...
sorry this was a dud reply.
but i may as well use it to reanswer the injector question.
they were on the plenum/fuel rail/motor when i picked it up second hand.
and yeah, nice to have up my sleeve if i ever go for more power.
Edited by gt-ahhh!
thanks. i will definitely hit up the tuner after the last few posts. i have no idea whats going on with the timing and vct etc etc. that was the only dyno printout i got.
intake pipe is factory item.
cooler is hybrid 600x300 with 3in outlets.
i thought the cat might have been blocked, so i went for a drive minus the exhaust lol. lots of noise, but no extra power.
in regards to air temp, they should be able to check this on the dyno yes? the ecu has air temp correction i believe.
looks like poor tune to me as it's making the right boost at the right time. could be a cam timing problem though too. also what headgasket went back in? standard size or thicker?
probably standard size. why do you ask?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
