So i finally took steps towards shielding my pod today
headed to bunnings in search of perspex
i was appalled when they wanted $45 for a smallish sheet so i bailed
buttttttttt............ on the way out i noticed they had plastic buckets for the princely sum for $0.94 so i thought to myself "what the hell...lets see what happens"
One bucket
Cut down one side of the bucket like so
See, all the way down
Looking good...but needs trimming
Trimmed slightly
Hole for the pod filter
Trimmed more
Trimmed bits
I think we're done
Yeah, thats gotta be better than a poke in the eye with a stick :(
I know its not high tech but its better than having a pod soaking up all the heat from the turbo and it cost less than a dollar
let me know what you think
https://www.sau.com.au/forums/topic/305214-toms-94%C2%A2-heatshield/
Step away from the bucket please :) .
Your car deserves better than this, what did it do to warrant this punishment?
Check out some plastics suppliers or use some flat alloy sheet.
I'd rather a poke in the eye, then I couldn't see what you've done.
Throw that abomination in the bin and let us never speak of this again.
Cheers, Dale
  • Like 1
f**k i thought i was being harsh.honesty is the best policy dale
Sorry if I offended you Tom, clearly you have excellent taste in cars, you're obviously having an "off" day.
It happens; I had an "off" day once, in the early 90's and ended up driving a Triumph :) . At least your mistake only cost 94 cents...
But please, take it off, it makes the baby Jeebus cry.
Cheers, Dale
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
