  • Replies 129
I guess I'll keep on driving and see how things are after a fortnight. Maybe rebleed again >_<
I suggest the MC is the right size. It's bloody huge :blink:
My suggestion is to bed the brakes in.
Somewhere on here is a procedure, but basically go to 80km/h and stop hard to 60, repeat around 6 times bordering on ABS engagement. Then 100 down to 40 twice bordering on ABS engagement, then cool slowly (drive around 60km/h with the occasional light brake pedal to slow and then speed up)
Don't ever physically stop... otherwise you'll warp disks etc.
I'm sure there are other brake pad bedding procedures etc, and my memory may be failing me.
After you have done this, it should be good to go and your pedal travel may decrease
Where the rotors machined before you got them or did you sand paper them before fitting?
Where the pads new?
I seem to remember Danny being a little underwhelmed with his setup until it was properly bedded in; similar to you, he was saying they were soggy to begin, but as they bedded in they were heaps better.
Where the pads new?
New rotors and pads...didn't sand it but I think Scott sprayed them with something to get rid of the anti corosion film.
I did about 2-300km's of driving after the new brakes were put on. So I guess maybe I should do more "bedding" in driving...
I am pretty sure Chris(Akebono) and Ben(Brembo) have not replaced there master cylinder or brake booster either.
Yep, Ben changed to the 350Z Brembo and I changed to the 370Z Akebono (just a strait bolt on - no other changes made). I have about 1 inch of pedal movement. No pumping... just shit loads of power. Ben's is very similar to mine. We had to bleed them 2 times till we were happy.
Driving around the street and bedding the rotors in are two completely different things. One you are just scraping the surface, and the other you are actually embedding brake pad material into the rotor which provides the stopping power you require and also 'moulds' the pad to the rotor (to some extent).
Bed and bleed. Job done.
they dont fit on our car.. 350z bay is VERY different.
:stupid:
I did read an Engrish blog yesterday where a modded NM35 running the Brembo's on 355 discs upgraded to a BNR34 master cylinder.
He said that it was a perfect fit and a definite improvement.
He also said that the Z33 would not fit and was a little upset at the wasted money lol
Edited by iamhe77
:stupid:
how am i stupid?
You buy it and tell me it fits. just like the engine cover with a spacer :nyaanyaa:
how am i stupid?
Sensitive? Would you prefer I simply put a "+1" if I agree with you :P
I was just offering a little information I picked up regarding a possible brake master cylinder upgrade.
At the risk of going waaay off topic with you, I have installed a few spacer kits where the owner wanted to keep the engine cover on... and they do fit without modifying/cutting. I'll have a look at yours next time I see you if you want.
Hmm screw the engine cover I'd rather fit a strut brace....
possible with the spacer?
OK, so the consensus is taht cylinder upgrade not needed.
Will try to bed them in tonight. Maybe rebleed again...u gonna luv this scott...
re bleed them after they've been bed in. i reckon anyway..
and cam you have my seals anyway so i should be seeing you soon. if you can make it fit with the bonnet closing? I'll be happy
Yeh yeh, the price just went up. :)
Where the pads new?
:rolleyes:
I did say my memory was failing me!! :nyaanyaa:
Their test sounds more aggressive. Really if you don't get the 'green fade', then it wont do anything.
  • 3 months later...
no, no you cant. Theres about 3mm gap without the spacer.
What is the capacity of our braking systems? Trying to work out how much fluid I need...
Also, opening a can of worms, how do you know what temp brake fluid you need?
Searching tells me everyone uses a variety, or doesnt talk about it, with Motul RBF600 the most popular. But when I was at Autobarn today, it was 3-4 times the price of the Performance DOT 4 alternatives from a variety of players. As far as I can tell theres about 30-50 degrees difference in dry boiling points (270-320ish).
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
