  • Replies 129
I guess I'll keep on driving and see how things are after a fortnight. Maybe rebleed again >_<
I suggest the MC is the right size. It's bloody huge :blink:
My suggestion is to bed the brakes in.
Somewhere on here is a procedure, but basically go to 80km/h and stop hard to 60, repeat around 6 times bordering on ABS engagement. Then 100 down to 40 twice bordering on ABS engagement, then cool slowly (drive around 60km/h with the occasional light brake pedal to slow and then speed up)
Don't ever physically stop... otherwise you'll warp disks etc.
I'm sure there are other brake pad bedding procedures etc, and my memory may be failing me.
After you have done this, it should be good to go and your pedal travel may decrease
Where the rotors machined before you got them or did you sand paper them before fitting?
Where the pads new?
I seem to remember Danny being a little underwhelmed with his setup until it was properly bedded in; similar to you, he was saying they were soggy to begin, but as they bedded in they were heaps better.
Where the pads new?
New rotors and pads...didn't sand it but I think Scott sprayed them with something to get rid of the anti corosion film.
I did about 2-300km's of driving after the new brakes were put on. So I guess maybe I should do more "bedding" in driving...
I am pretty sure Chris(Akebono) and Ben(Brembo) have not replaced there master cylinder or brake booster either.
Yep, Ben changed to the 350Z Brembo and I changed to the 370Z Akebono (just a strait bolt on - no other changes made). I have about 1 inch of pedal movement. No pumping... just shit loads of power. Ben's is very similar to mine. We had to bleed them 2 times till we were happy.
Driving around the street and bedding the rotors in are two completely different things. One you are just scraping the surface, and the other you are actually embedding brake pad material into the rotor which provides the stopping power you require and also 'moulds' the pad to the rotor (to some extent).
Bed and bleed. Job done.
they dont fit on our car.. 350z bay is VERY different.
:stupid:
I did read an Engrish blog yesterday where a modded NM35 running the Brembo's on 355 discs upgraded to a BNR34 master cylinder.
He said that it was a perfect fit and a definite improvement.
He also said that the Z33 would not fit and was a little upset at the wasted money lol
Edited by iamhe77
:stupid:
how am i stupid?
You buy it and tell me it fits. just like the engine cover with a spacer :nyaanyaa:
how am i stupid?
Sensitive? Would you prefer I simply put a "+1" if I agree with you :P
I was just offering a little information I picked up regarding a possible brake master cylinder upgrade.
At the risk of going waaay off topic with you, I have installed a few spacer kits where the owner wanted to keep the engine cover on... and they do fit without modifying/cutting. I'll have a look at yours next time I see you if you want.
Hmm screw the engine cover I'd rather fit a strut brace....
possible with the spacer?
OK, so the consensus is taht cylinder upgrade not needed.
Will try to bed them in tonight. Maybe rebleed again...u gonna luv this scott...
re bleed them after they've been bed in. i reckon anyway..
and cam you have my seals anyway so i should be seeing you soon. if you can make it fit with the bonnet closing? I'll be happy
Yeh yeh, the price just went up. :)
Where the pads new?
:rolleyes:
I did say my memory was failing me!! :nyaanyaa:
Their test sounds more aggressive. Really if you don't get the 'green fade', then it wont do anything.
  • 3 months later...
no, no you cant. Theres about 3mm gap without the spacer.
What is the capacity of our braking systems? Trying to work out how much fluid I need...
Also, opening a can of worms, how do you know what temp brake fluid you need?
Searching tells me everyone uses a variety, or doesnt talk about it, with Motul RBF600 the most popular. But when I was at Autobarn today, it was 3-4 times the price of the Performance DOT 4 alternatives from a variety of players. As far as I can tell theres about 30-50 degrees difference in dry boiling points (270-320ish).
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
