  • Replies 63
I wonder how many of those workers did a few final hotlaps...
Would be abnormal not to if you ask me. I'm a QLDer so don't really have a close connection to the track but to see any track closed sucks. Are they making another as a replacement?
Only did OP GP once and South once, Im kicking myself........
Im a noob but I feel your pain, that wall on the straight was WTF, and pointing my car at a tree in the distance to get through the flip flop was the funnest and freakiest thing Ive done in a car.
I want to souvenir a piece of tarmac. any suggestions on how???
Bit late now BB :D But you might be lucky if you head out there...and see if there is any left...
People were taking bits of Tarmac over the last weekend
this thread can't die yet!
Paul, Pete and Mark would remember this day....and where is Toulia these days?
skyline ran out of tyres so I had to grab the "t-car" for the race.
my race car debuted at oran park, the day after I got it from the boat. and thus began my long romance with engine rebuilds
Kel did her first standing start race there....and dished out chop chop on scott!
Marks car at OP (RIP, the car and the track but not the bloke)
from absolute years ago......proof my car even without a rear windscreen is quicker than john's z
day night race meets....I did 2 of them there, they were the best races I ever did.
recently
zooming at suttons
even the march got to run there before it was too late
I only ever hit the scenery there once, took a mirror off the daewoo on the milk sign. I had some decent crashes there back in the woo days but they were all car on car. actually here is one of them - I tried to get thru turn 1 flat 2 wide (fail) lap 1, then on the next lap after the safety car I got thru turn 1 flat but the car in front did not. http://www.hgeconsulting.com.au/woocrash.wmv.
Not my best crash there, the best one was when I managed to hit 3 sides of the same car in a single crash at the last turn.
I've got a funny vid or 2 to come but need to rip in from dv first....
even got some shots of TWO.06L going around in the early days somewhere. That was before Stacey took it drag racing and removed the steering wheel and middle pedal.
Dunc's that night shot is a cracker!
Used to go there with my dad back in the Group C and Group A days.
Oran Park was the first track i ever ran a full bodied car on.
Ahh you guys must feel awful looking at those shots...very sad indeed.
I think I should post up a few photos of OP - Lest we forget
Flip flop, dogleg, call it what you will but it was a thing of beauty...
Home to flying GTRs
flying Civics.... (I believe his Vtec has just kicked in...yo)
upside down Evos...
and upside down Imps...
It looked great by day, and by night
was a place where screaming Rotaries and cows co-existed peacefully
and nature framed the track
It made you look like a hero when you got it right
Nipped you for the slightest error
and bit hard when you really stuffed up...
Whether it was sideways over the bridge by day,
or straight-lining it over the dogleg at night
There was nowhere quite like Oran Park. RIP.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
