THe pic where taking in like 1min umm yea well i like my chromies i still run 11sec 1/4
I have drift r rims i might put them back on but i beat would be a lot quicker +the girls like the rims lol ;)
Just my 2 cents.
Being a girl, i can say we do not like the rims (at least all the ones i know dont)
Its usually dudes that like those rims ;) dudes in commodores.
I dont mind the missing wing, i like the colour of the body (white interior is not so good IMO)
and im not a fan of the back window stickers, i usually see that as a falcadore thing to do too!!!
But its not always about the aesthetics, it is about the engine too
post another pic so we can see the kit better maybe one of the engine too!
(having said that im at work and generally cant see most photos on these forums so dont slam me if there is one)
  • Replies 211
Posted Images
Well unless you're using one of these
I'd hope it only took a minute
it has after market prtey much evry thing the turbo is dieing but it lasted a good 3mouth and i got the dyno il get back to you when i findthe print out moved house some stuff in storage
the turbo lasted 3 months??????
Wow...props to you my friend.
Have to say it, i'm gonna agree with the majority of the people in this thread.
Rims = horrible. If you have drift R rims, put them back on. Anything would be an improvement
And tell the truth mate. I know what it feels like to try and be cool and make up sh*t to impress the ppl on here (yes i've done it...and i'm not proud of it)
But seriously, it's not worth it, you're only wasting your time..no one cares if you've only got a stock R33 that runs 15s. As long as you're passionate about the import scene, take note of advice ppl give you and are willing to learn things from people who know more than you
I was going to copypasta something then that would probably have offended you unintentionally Passive so I won't lol
Lol ta?
i only read the first few posts before putting mine in
Plus this is my eleventh day at work straight so my brain isnt functioning as well as it should be ;)
mate if you look next to the 11.79 on the drag slip you will probably see that is says something like 1/8 or possibly 800m.
or you are running drag slicks and have a very large 'magic' bottle in the car.
but if you really did run an 11, you shouldn't have any problem letting us all know the speed it ran it at and your 60ft time.
all else i can see is that it smells like herd of cattle that had eaten something dodgy spent the night in here
sorry, but you asked for my opinion, so i'm gonna give it, ;)
rims - fail
no wing - fail
white interior - epic fail
clear tail lights - epic fail
2/10
get decent rims, put back the stock tail lights, drop it 2 inches, remove the sticker that says drift and you'll be getting somewhere...
remember this is just MY OPINION, and i'm not just being a flamin mongrel ;)
lol agree with above. plus remove the tisonics alarm sticker on the rear quarter window... cheapo alarm why advert it
tint the windows too
rate it 2.5
11 second quarters ,,, yeah right being pulled by a 747
1st my mate drove it down 1/4 went to syd for the week whn i 1st got it 11.79 and now its defected all back to stock and wen you strip it seats/boots jack other stuff made 247kw and with boost and as you noe most mods i hve spent over 38ganrd on the car i noe what ican do
come on man. dont insult us with those stories
What about those two years you did in juvie for boosting cars? Tucson, right? I had Jesse run a little background check on you, Mr. Brian Earl Spilner. He can find anything on the web, anything about anyone. So, why bullshit?
dont call people greek. cockhole
i cant believe i missed all the fun... i tried to stay away from here, knowing exactly what was inside..
but alas, i canna help maself... GIT IN MAAA BELL-EYYYY!!!
38g could get you 3 preludes with fork engines.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
