  • Replies 1k
Posted Images
Half way there.
Had to use some plastic filler on the back of "26" because it is pressed out and would have been a hole once I shaved it off. So did that and shaved the "26" off and turned out pretty damn good. Just says RB :D
Then cut the hole for the VCT which was a pain in the ass, not 100% happy with it, will fix it up a bit today.
Started shaving back that backing plate but it was getting late so I will finish that off today.
Then just need to paint it and i'm done
I might be if the car is running. In a hundred pieces at the moment. God I hate taking the harmonic balancer/timing belt off.
Got the backing plate cut nicely now, everything fits.
Just gotta put it all back together tomorrow and install the new oil seal and thermostat.
Well I think I f**ked up that RB26 front timing cover god damnit!
Went to paint it and had it perfect. Did a quick undercoat and then when I put the blue on it went all bubbly and shit. No idea what happened but I had to spend 20 minutes getting all the paint off. In the process the part where I shaved the "26" off cracked and went to shit and I can't get it smooth again.
Gave it a bit of paint then but it looks crap and doesn't even match the colour of the other ones.
Just f**king great.
I think i'm just going to rip them all off and send them to get powder coated at the same time. So over this.
  • 4 weeks later...
Just f**king great.
Hey Phil. I dont know if this helps, but I had a similar problem when we re-sprayed the engine bay in my old VL. When sanding it back we didnt take it back to bare metal just sanded the top coat off. Pretty sure we didnt get all of the clear coat in one area and it made the base coat go all strange and almost like little holes (Inverted bubbles I guess is a good way to describe it, might be similar to what your describing)
Funny thing is the undercoat went on perfect and we prepped that as normal.... Then the base (metallic) coat went on with this strange problem. Ended up getting it as good as possible then putting the clear coat on.
So it may have had to do with the prep? I'm not sure how far you sanded it back etc so just a guess
  • 4 weeks later...
Hey Townsville skyline owners. Any of you know who a good person is for wheel alignment for track cars here in the ville. there's a bit of suspension work I want to do to my 32 and want an experienced hand who can help me out along the way and answer some of my q's in terms of costing etc etc. I don't know anyone round here and hoping you guys could give me some sort of clue. appreciate any help
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
