wrecking a complete r33 series 1 skyline manual turbo
damaged lightly at front
if any parts needed
located in sydney
contact karl 0435 310 488
will sell whole car $4000 ono
starts and drives, blue - green standard colour
https://www.sau.com.au/forums/topic/306506-wrecking-r33-series-1-turbo/
hi mate
I'm in sydney and im interested in your complete motor, as long as its still in good condition and wasnt damaged in the hit.
Alternatively i'm after your turbo, the coolant lines and oil lines for the turbo
send a pm if the motor is good. Thankyou
jeff
EDIT: maybe intersted in whole car too!
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
