Justin, yeh I think they probably are meant to go into the cabin. However I wouldnt have any room to mount them all inside without it looking silly or taking up a fair chunk of room. So left it out in the engine bay. Hopefully they wont get too wet there as they are not exactly water tight lol.
Didnt work Justin.
Edited by r33_racer
Didnt work Justin.
I'm planning to run mine into the glove box or up behind the dash.. Apparently they are fairly sensitive to water and rough conditions... If you do go Vipec, they are compatable and plug right up. Do your thermocouples penitrate into the gas flow or just in the bung welded on the outside or each runner? I keep getting different advice-
PM again.
Ok. Busy day yesterday finishing it all off. Took it for a drive and it ran like shit, as expected. Some further playing in the datalogit with the injector settings smoothed that out. Still doesnt like coming onto boost so early. My guess the fuel map isnt too good for the 0.5-0.8bar of boost it makes as soon as you stomp the gas. The overboost valve is working, hence the low boost.
Ok the catch can does have some baffling inside of it. But it appears to breathing fine. Guess ill find out on the dyno when it counts.
The electric power steering pump isnt setup yet. Its last on the list of things to do. I Will mount it and hook it up once everything else is sorted and working fine.
Interesting you say that justin, cause a few times ive seen mine read some funny temps, maybe engine noise/vibration is causing this... But the actual sensor ends of mine protrude into the runners, so they have gas flow running past them. Well I may have to re run them back into the cab somewhere if it keeps up. Goddamit!
Ok so the good news is there is a video I did yesterday afternoon. It just shows it running. Its not that good and it has me coughing and speaking in it a few times. My apologies.
http://www.youtube.com/watch?v=eHCbYgR3mBg
ok so i just dropped the belt and took it for a drive and it was fine in na form. so it seems its just the tune thats making it hesitate when it tries to boost. i was worried it was a mechanical issue with the setup.
So there was a blow out from the discharge port. The aviation goop I used (loctite 3J) wasnt strong enough to keep the two faces sealed even though they are machined. Dont know what RA it would have been. But I know I had to re-mill the face of the outlet pipe flange after welding as it bowed a little. I would have thought with the 3J it would have been good enough, guess not. I refitted both the outlet pipe and bypass valve and regooped them up with some threebond. Hasnt fully cured yet, but did a quick 6500rpm stab and it made 1 bar of boost and it seems to be holding perfectly. No signs of leakage from around the flange face. :(
Now the overboost valve was fully open and screaming when I did that and it still managed to push 1 bar of boost upto the plenum. Starting to think it might not be big enough. But hopefully once its tuned it would be needed to control boost. It also is stupidly loud when its venting. Other issue is when you let the throttle off sharply, the pressurised air goes out the bypass valve and I think goes out the intake and through the afm...bringing back the unstable idle issue for a second as the revs stabilise. I may need to fit a BOV.... :rofl: I was hoping to avoid having one. Another thing Ill have to see if necessary after dyno tuning.
Man that thing is wicked! 1 BAR free revving, haha must be hitting load points its never even been close to before.
It'll be interesting to see what its like after the tune :P
Got to get me one of those twin screws.
Cheers Simon! Im sure you will see it. It will have to be one of those days when there arent any cops to be seen for miles!
Yeh the 1 bar is pretty crazy. Im not sure what boost its even going to make when its fully on song with the overboost valve locked up. Hopefully nothing too stupid like 30+psi. Well tonight we re did the egt modules and put them inside the car, in the glove box to be specific. It was a shit load of mucking around to get them in there, but its done and working. Which im happy with, though I must admit, sparkies must be just brimming with patience, because it took forever and it was a carnt! I cannot stand wiring. Anyway, its all done now, just needs to be tidied up after the ecu goes back in behind the kick panel.
So hopefully tomorrow nothing goes wrong and it all just does what its supposed to do :D
I just read through all 11 pages of this build r33 racer...fantastic to say the least.
Good to see someone tackling something different & should yield some very good results once tuned !...post tune results asap. :)
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
