Hi all,
Before you say "use the search button" I've searched and found some conflicting advice; I read that R33 fits, and R34 fits?
I've contacted a Natrad dealer here in SA but it's been a couple of days now and nobody seems to know anything. JustJap have got alloy radiators for a good price but no autos.
Could you help by filling in the table... I'll start with what I "know" from reading the posts here... Obviously the manuals should suit their manual equivalent
Series 1 auto = R33 auto radiator, stagea fan shroud will bolt back on?
Series 2 auto = (R33 or R34 auto radiator)? stagea fan shroud will bolt back on?
https://www.sau.com.au/forums/topic/307026-which-radiator-fits/
ive fitted KOYO 53mm R34 GTT radiator, no problem. Didnt worry about auto radiator, no need, slight mod to side of factory shroud.
how much did u pay?
i just got the just jap 40mm one for $365 inc postage, just wondering if i could have gotten something better for the price
That's great stuff, thanks guys. So we could say that R34 fits S2, with slight modification to factory fan shroud? Could you tell us what you had to do to the fan shroud exactly (like cut some off, or reposition the bolt holes etc?)
Well, looks like it's no good. After lots of research and phone calls, I can't find:
a) anything alloy with the auto trans cooler
b) anything to suit R33 or R34 with the auto trans cooler which is thicker than 16mm
So it looks like I have to ditch the auto trans loop and put up with the longer time to warm-up. Just have to drive it harder in lower gears or something :blink: because the only option I have found is a custom-made alloy job with trans cooler for over $900. I suppose I should be grateful for that price though really since a genuine Nissan job is over $1,000 and that's only 16mm thick and has plastic end tanks!
One more question guys... are R33/R34 top & bottom radiator hoses the same? And which one suits Series 2 Stagea? :| I've FAST'ed for ages and they look different to R34 skyline... but I couldn't find a VIN for a turbo, which may be the same...?
Dave get them to check as there is a Radiator that`s same as Stagea i did chat to my guy here he found then ,+ it was thicker then stock on in mine ,as i toke him mine & one from 32gtst he looked & found them all in his BOOK ADRAD so get them to look harder & i think Price was about $450 & that was for Auto ok ,I will try to find out some detail`s sunday from him ok ,cheer`s Chuckie .
Thanks Skidkid and Chuckie; yes I called the Adrad distributor and he was good enough to search for me, spent some time on the phone to him, however he didn't know about anything for stagea and I suggested 33 or 34, but we only managed to come up with NIS068PACAK which has the plastic end tanks and is only 16mm thick.
Oh, and a price from a dealer was around the $550 mark.
I guess if I actually took my radiator in they might be able to find something. 1" (25mm) is thicker than 16mm too so I might check that one out.
Hi Dave ,We did find TOP TANK ,but no bottom tank ,as it`s TOPTANK that give`s up first ,i have talked to my Rad man this morning i shall meet him in week & get all DETAIL`S again & POST THEM UP ok ,but i know that the one we found was 25mm thick so that will be much better then all current one`s ,cheer`s Chuckie.
Cheers Chuckie, I think that is the go; I will take the radiator to the radiator place Monday afternoon and try to get hold of this 25mm core radiator that is a direct replacement; I am now armed with the Jayrad part number just in case they don't know what fits :happy:
As you say, 25mm is better than 16mm. And it is less than the 16mm Nat/Adrad replacement.
Buy a R33 ebay 40mm special for $200(delivered) and fit a trans oil cooler from supercheap $50.
If it ever leaks, just TIG it up!!!
lol OH to have a TIG welder in the garage... and the experience to use it without blowing holes in the work. Unfortunately I already have a good trans cooler (the stock one) but I need a trans *warmer* :) Funnily enough this is foreign to all of the radiator experts I have talked to... maybe it is true what they say, take your job to an 'expert'. And the trans expert says I need a trans warmer...
Hmm yeah I guess it's pretty hot in Queensland :)
Anybody know which radiator hoses (top & bottom) fit for us series 2 guys, by the way?
...and are R33/R34/GTR hoses the same?
im gonna go with r33 gtst, same chasis same motor, if you get gtr stuff it may be different cos of the awesomeness of the rb26's
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
