Hi Fellas,
I was recently having a few issues with my car with low power output. However, I change the spark plugs (Put NGK platinum ones) and the power was back up (wheels spings in 3rd gear :down: )
Anyway, 3 weeks of driving, the power is back down, had a look at the spark plugs, and they are fouled, yet again...
I cant keep forking out $150 every 3 weeks to change the spark plugs, so what do you guys suggest?
I have a built rb25/30 block, forged pistons, rods, the whole shabang. GT35r turbo, Autronic SM4.
Went to the tuner last week, AFR were perfect throughout so I am not too sure whats causing the fouling? Will I need to get hotter plugs? I am currently running the NGK PFR6G-11 5555 at 0.8 gap.
Not sure what heat rating these are.
Any suggestions are welcome.
CHeers fellas.
https://www.sau.com.au/forums/topic/308303-spark-plugs-keep-fouling-why/
Do you have any rich spots in your tune, even small events? i.e. just coming onto boost, or injection cut on deceleration?
Are you getting any misfires, especially on boost?
as i understand it, plugs foul cos of rich condition and/or lack of spark (not igniting the mix)
maybe something to do with the gap?
with 22psi (going by whats in your sig) you might need a colder plug. most people run 6s on stock engines/lower boost.
what did your tuner have to say?
good luck bro
what kind of driving do you do?
constant short trips (5mins or so to work i the morning) when the car is cold and not hitting boost can foul plugs pretty easily...
if this is the case take it out for a nice longer drive and boost it a bit... it should clear up.
otherwise, look at your tune again... most likely too much fuel somewhere.
plugs to use would be bcpr7es @ 0.8
Pretty much 5-10 min drives to work and back each day, car doesn't even get a chance to fully warm up.
As for these bcpr7es, what heat range should I get?
How long do these spark plugs generally last?
I wouldn't mind changing them once a month, anymore than that gets annoying....
Thanks for the input :P
Theres your answer, you need to trim the temp compensation.
bcpr7es, usually 7-12 months depending on driving Kms.
the 7 in the number IS the heat range
mine last 20,000ish with 300rwkw
if your car is always on cold start / idle then try giving it a good run and boosting it for a while and see if the plugs clean up a bit.
if they do then you know which part of your tune has too much fuel
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
