Lol I had to stop and look when I saw Joeyjoejoe asking about bodykits. Something just wasn't right :D
Its hard to go past custom wide body from CARBON (painted to look factory) including unpainted carbon front splitter and rear diffuser. With a V8 supercar style spoiler to pull off a suitable GT car effect.
That said. Very impractical for real use so i'm going to stick with nice simple add on front lip and a gtr spoiler. Leave the rest of the bodywork standard. Very practical, generally looks clean, cheap. Easier to replace/repair a lip then a full bar and it looks much nicer to me then a big chunky missmatch of parts (or veilside :down: )
Luke
multiple choice time!
which is:
  1. a higher center of gravity height
  2. a lower center of gravity height
the lower you go, the better.
I can prove this with science.
Yes please, Whats the reason, explain this science, we are talking about road going cars that hit the track as well, yes ?
My car handles much better since Ive raised it up to SKs recomendations, Have I imagined this ?
cbf condensing a 4 (well 5.5 for me) year long engineering degree into 3 lines, so here:
http://en.wikipedia.org/wiki/Car_handling#..._gravity_height
no, you are. no one mentioned any track going cars. but even in track going cars, the lower you get, the better. Obviously for safety sake you try and avoid catching oil sumps etc on ripplestrips. I have a blatant disregard for ADR's, therefore I run my car as low as my sanity and my wallet will allow.
yes, but we're in the cosmetic and styling mods section, not the suspension and braking and tyres section or the motorsport section. Aesthetically, most bodykits are designed with the car sitting quite low in mind. refer to promotional material for proof.
Suspension travel
The severe handling vice of the TR3 and related cars was caused by running out of suspension travel. (See below.) Other vehicles will run out of suspension travel with some combination of bumps and turns, with similarly catastrophic effect. Excessively modified cars also may encounter this problem.
This is what you referanced.^
Still relevant as the kits all sit at different heights, my 400R was 50mm of the ground which was getting cracked on bumps and such.
So, in closing, get what you like but be carefull and dont whinge when you smash your nice new front bar because your car is set too low and hit that manhole cover, or you crashed after hitting a bump mid corner and went into the gutter.
Low is slow.
Your confusing two different things.
(a) Lowering a normal car as low as it can go before it hits the ground
(b) Having a car built to be as low as it can to the ground.
It's not just about centre of gravity, you have to look at what all the suspension of the car is doing.
i has a lemon?
lol i think the do luck kit is sex but then the 400r kit is sex but then the top secret kit is sex >< guess it goes by wat u like at the end of the day :D
I have the 400R bar and once it is sprayed will be ready to go on, have the top secret front bar and ripped it off at a drift day, it is now zip tied together lol :no: Have a vielside rear bar and hate it, i hate vielside. Will change that shortly.
As with ride height, optimal turn in and performance is as close to stock height as you can get (even with a new suspension setup) - Was told this by one of the best suspension guys I know of and the car handles amazingly well.
I have the 400R bar and once it is sprayed will be ready to go on, have the top secret front bar and ripped it off at a drift day, it is now zip tied together lol :) Have a vielside rear bar and hate it, i hate vielside. Will change that shortly.
Could you post some pics please?
Edited by ON EDGE
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
