Hey.
Just bought myself a super dardy 10 row oil cooler, just need some help with it.
ive got brackets for the cooler and filter already sorted
obviously i need an oil filter relocation kit, but how do i plumb the cooler in?
should the oil go: block > filter > cooler > block or: block > cooler > filter > block?
also ive got the turbo's oil feed coming from a filter sandwich on the block, so do most relocation adapters have ports for feeds and oil pressure senders or do i need to tee one of the lines?
also is braided hose a must? or would heavy duty oil retardant blue stuff be ok (with the appropriate fittings??
Thanks guys!
https://www.sau.com.au/forums/topic/308782-oil-cooler/
usually the relocation/sandwich plate has the correct location points for a cooler. I like your first option btw, no 'dirty' oil clogging up the arteries, plus it will filter better hot before it is cooled.
https://www.sau.com.au/forums/topic/308782-oil-cooler/#findComment-5094813
who did u get the kit off,
when i got my kit it had sandwhich plate relocator and lines, as ur set up is different im not sure about ur turbo feed, but my locater came with two ports i presume for pressure and temp. u could prolly use one of those for ur feed
also i run block filter cooler block,
on the up side if u do run the feed off the relocator u will have super clean oil going to ur turbo, but it wont be cooled,
https://www.sau.com.au/forums/topic/308782-oil-cooler/#findComment-5094847
Ksweetthnx.
What about the line? Is braided hose a definate need or is heavy duty rubber ok?
Should i need a thermostat for the cooler too?
or is that not really a need?
Also, what size are the outlets on the top of the cooler?
are they likely to be -10 or -8?
they are 8mm ID and the thread is like 17mm
@ daniel: the cooler came by itself. got it from a member on here...
https://www.sau.com.au/forums/topic/308782-oil-cooler/#findComment-5094962
Mate as far as your hose goes, braided is not essential. I have a remote oil-filter & hoses ready for oil cooler (routed but looped back until tuning is sorted) & use high-temp, high-pressure 'rubber' hose. 99% sure what I use is called Aeroquip. Definitely have the name but am falling asleep as I type... (on my phone) Can confirm tomorrow.
Anyway it is a really thick chemical-resistant blue hose... Awesome stuff but not real cheap!
Also use the same stuff for my turbo water feed/return & oil return. They have been on there for years & when I recently inspected them while the engine was out they were honestly as good as new!
Good luck,
Brett
https://www.sau.com.au/forums/topic/308782-oil-cooler/#findComment-5095000
they look like -10 to me.
And yeah, filter then cooler is preferable but not essential.
Re the oil feed, most adapters have a couple of ports on there for gauge senders which are pretty small. I don't know what size feed you have though so cant say yes or no.
You may want to consider one of these if you haven't got an adapter http://www.tuneagent.com.au/public/merchan...em.aspx?id=1307
I'd use braid but it isn't really necessary.
https://www.sau.com.au/forums/topic/308782-oil-cooler/#findComment-5095253
Hey.
Thanks guys!
All the setup i have seen run Block -> filter -> cooler -> block
I run a HKS oil cooler kit, and on the relocation adapter it has the 4 ports to connect the lines to plus an extra port which is block by a fitting, if you could use something like that then you can connect the line for the turbo.
Most j-spec relocation adapters have an extra spot for an oil pressure senders (most of them will be on the fitting which goes onto the block)
Here is an example: http://www.nengun.com/trust-greddy/oil-filter-moval-kit
as you can see from the pic it has the ports for the pressure sender (however you want something with 4 ports were the filters goes on).
Also you can tee off one of the lines for your turbo oil supply i would do it from the one which goes from the reloacion adapter to the block (so it has already been filter and cooled)
https://www.sau.com.au/forums/topic/308782-oil-cooler/#findComment-5095548
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
