  • Replies 74
i am just trying to organise getting the day off work, but most probably will be getting my entry in for driver training this week. you should enter driver training too, then we can get our team wang racing stickers!!!1
hmmm will sit out for this and come watch :cool: maybe get some pointers from track gurus
I could be mistaken but I think you need to do Phillip Island to qualify for the stickers!
You are wrong.....you need to stay at the Wang to do Winton to get the stickers :P
But if you really want the stickers just contact Bec :ninja:
im going to come down to watch, will they let me in just to watch? or do i have to be participating to enter. is the front gates open or only allowed through the side gate?
i was going to bring some friends down so make sure you guys show them what skylines can do.
there were no mod rwd there on the day iirc?
but the standard rwd belongs to me now?? :)
was an awesome, day...errrr night..
had a ball!
there were quite a few blowups / failures / offs.
include marty and I.....:nyaanyaa:
so after hearing wat andrew was saying about brake temps in the first session i thought i should give the car an even longer
cooler down in the second session. though it didnt help.
brake pedal was hitting back at me, though it may have just been warped rotors....
got onto the pre grid for the 3rd run, in the dark. this is going to be cool, glowing brakes, great pics of the flames from my car.
hrm i better check those rotors.
shit im out :)
just on the outside part of the disk
but then get home :nyaanyaa:
but that is all the way through.
edit: oh they are dba 4000, so expected anyway...?
Bugger, i cracked a rotor at Calder too. Matt, what was your best at Calder? I am pretty sure between Ryan and a few others that none of mine or your times stand ay any track aymore :)
At Calder i think my best was a 1:06.4, LOL with a cracked rotor, crabbing on the road anda hot day with a pinging engine with flat spotted tyres from Dutton :) :) It was my last track day in the 32 and the reason why i stopped tracking it until i had time to go through the car and do a refurb on much of the suspension, fuel system and brakes at an expesnse its take me a few years to afford.
But fark help you all when she gets back out there :)
Bugger, i cracked a rotor at Calder too. Matt, what was your best at Calder? I am pretty sure between Ryan and a few others that none of mine or your times stand anymore :) At Calder i think my best was a 1:06.4, LOL with a cracked rotor, crabbing on the road and pinging engine :) It was my last track day in the 32 and the reason why i stopped tracking it until i had time to go through the car and do a refurb on much of the suspension, fuel system and brakes
my time still stands.. 1:05.4 back in 2006!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
