I recieved my Mishimoto low temp thermostat today from the states and plan to fit it tonight. Is there a special procedure for bleeding the system?
My informeter displays cruising temps of 93 degrees and up to 105 while stuck in traffic so hopefully the 62 degree thermostat will help lower the coolant temps substantially. I have also seen intake temps over 85 degrees while stationary too, which im trying to lower also.
I picked up some Nulon coolant and MoCool Motul additive, hopefully the standard radiator is up to the task.
https://www.sau.com.au/forums/topic/309344-m35-low-temp-thermostat/
Scott, just unscrew the air bleeder from the line at the rear drivers side of the engine (I also undid the overflow bottle and the radiator cap), then open up the bottom plug on the radiator.
Edited by iamhe77
I was told you need to change it at 5k and filter at 10k, of course I have a box of filters now so I will be changing them with the oil.
Ive been meaning to do it anyway as I still have a bit of smoke at startup and wanted to try slightly thicker oil. I have 3 liters of 10w and 2 liters of 15w so I will see how that mix goes.
I should think the new thermostat will make no difference to your top temperatures - your stock one would have been wide open by then anyway.
If you use an expensive high quality synthetic oil it should be good for at leat 30,000km. If you change your filter at say every 10k (or more often if you like) the oil should be fine.
Soon see if it makes a difference, im confident it will. Obviously the thermo fan kicks in quite high on these alloy blocks. The thermostat box stated 20 degrees cooler running temps, it can only help.
I will leave the oil for 10k if you all think that's fine...
i change my oil every 10k. 5k on an SR20 as its always high up in the rpm, the VQ25DET performs pretty well (in fairly stuck form) under 3k. oil should be fine, but as cam said, id be doing the filter with the oil regardless of how often you change it.
Hi Scotty,i have S2 stagea, i do 20,000 pre oil change + i have been SAMPLING my oil,WESTRAC here in Perth do sample kit`s at $26. great price as i set up trend & see what is happening with my oil,i change Filter at 10,000, Nissan Filter aswell,there is some detail`s on my OIL SAMPLING,+ if you go with relocation filter you can Move it so it will be easyer to remove ,good luck Cheer`s Chuckie.
I have a cooler/relocation kit here but I like where my filter is now is now, right beside the drain plug.
Probably no need for the oil cooler now that the water sits on 70 degrees. :rofl:
dont want to rain on your parade, but a lower thermostat, especially one this low will do a couple of things.
Firstly, if you are running a stock ECU, the engine will be constantly trying to warm itself by running rich until the proper temps are achieved...hence higher fuel consumption, lower performance and added engine wear on cold days (engine clearances are designed for the stock temps). Also it wont lower the temps on hot days, as the thermostat will be fully open on both standard and low temp thermos ay around 90, so no difference.
Your temps are not that high, consider a radiator upgrade first.
If the mixtures are out I will adjust them with the emanage, but I doubt it will change much. The car runs like balls when its over 100c that was the priority. I will let the good M35 blokes know how things go.
Cam is running the Nismo thermostat without issue so I doubt it will be a problem.
Radiator, yes I would love one. Do you have a bolt in solution for me? I will be upgrading this next, after the ecu remap. (which will bring the thermos in at lower temp too.)
Edited by scotty nm35
I have a bolt in solution for you.... but you can't have it :P
There IS a semi-bolt in solution if you want it.....
Ok, I went for a cruise today to check out the temps and mixtures. It cruises on 75 to 80 degrees now so a 15 or more degree drop which is what I had hoped for. Intake temps seem down by 6 or 7 degrees and the mixtures are much better at 11.8-12, from a slightly rich 11.
Very happy with the result, the car definitely pulls harder and seems to shift better too, probably from lower trans fluid temps.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
