Has anyone with an NM35 had to replace a fuse? I've just realised my interior electrics arent working (electric windows, and sun roofs specifically) - but the radio, wing mirros etc is still all fine. I'm assuming I've somehow blown a fuse over the course of the last week.
I managed to locate the fuse box, and the back cover of it has a description of them... in japanese. The wiring behind that panel for me is an absolute dogs breakfast though! I had to take the entire panel off (not just the little cat flap cover) to see the fuses! Must be for the alarm etc :cheers:
Any how, heres what I'm working with :cool: If anyone has the feintest idea which one might be something like 'electric windows' or something it'd be much appreciated!! :D
Cheers,
Dunc
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/
did you accidentally short something out playing with the monitor? If you cant read it just pull everyone out one at a time and have a look at them until you find the blown one. If you have a multi meter you just go down both sides of fuses until one dosent read 12v on both sides. When you find it if it blows again you have a 12v+ touching earth somewhere. That plug from pic 2 in other post might be on the same circuit as the sunroofs.
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5107173
That was my initial thought, short something while playing with the monitor, but I havnt connected anything up - unless I one of the screws for the mounting plate in the roof managed to pierce the plug =/
I realised the windows weren't working on my way to get the multi meter, sounds like I can put it to good use now :cheers:
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5107187
Well I didnt use my multimeter for it simply because its too difficult to use in the footwell - my height doesnt really help make me 'nimble' either. Took out every fuse and inspected them.. all looked fine :cool: I'll see if the missus can help me translate some of the kanji tonight
Edit
Just removed the mounting plate and the windows are now working. Remote lock via the keys now seems to be on the fritz, unlocking does work though.. today perhaps isnt my day! :cheers:
Edited by Dunc
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5107269
So with the help of the missus last night, we now have a translated version of the fuse box :P I've left it as the 'direct translation' as its more amusing that way, 'room lamp' :P it should all make some degree of sense though. Hopefully it proves to be of some use to someone else eventually :(
  • Like 1
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5108325
So with the help of the missus last night, we now have a translated version of the fuse box :ninja: I've left it as the 'direct translation' as its more amusing that way, 'room lamp' :P it should all make some degree of sense though. Hopefully it proves to be of some use to someone else eventually :)
I'll be saving a copy, thanks :)
I'm sure it will come in handy, I'm yet to check my fusebox to see if anything was removed during compliance for any reason.
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5108436
  • 9 months later...
How'd you go with the remote key Dunc? Might be good to let us know just in case it happens to us? :happy:
Never did work out why the remote was playing up - seemed to correct itself the next day without any interference from me; I have an alarm/immobiliser with its own lock/unlock fob which I use now, and thats been flawless :)
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5580575
  • 2 months later...
there is no fuel computer as i far i know.. the factory ECU handles all the petrol and lpg fuel delivery :) thats whats so good about liquid injection. anyways its done now!! picking it up tomorrow morning! will post in the LPG thread my thoughts and pics tomorrow :)
Edited by Sage222
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5666521
  • 1 year later...
Has anyone on Importing had their front screen fuse pulled out? I forgot to get it put back in and dont know wether it was the one in the engine bay or kick panel? And if so do we know which one it is on the nm35, I have an 03 Axis if that helps :)
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-6503767
  • 2 years later...
I may have a short circuit somewhere and want to locate the Fusepanel and test it with a multimeter.
Where are the panels and how do I gain access to them . Tried searching for some images
to help me but no luck.
Obviously I am not very mechanical !
thanks in-advance.
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-7406686
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
