lol. shan, i would come over but im gonna paint the shit while im at it. will take lots longer.
i've got 1 r33 gtst caliper, 2 front slotted rotors and a full set of pads for a 33 gtst in my garage if it helps lol
whatevs.
hey guys, this is prob the wrong place to ask this, but im gona do a manual conversion on my 31 but i still need to get a box. if anyone has a r32 rb20 5speed in good nick, pls let me know :blush: mods if this is the wrong place to put this let me know, wasnt sure if i can start a thread in the vic section for a wtb, dont wana chuck it in the wtb section cause i just want one that in melb. makes it easier to go pick up. thnx guys :)
small amount of rust repair, shave bump strips, add series 1 bumpers, respray
mine needs some dings popped out, rust repairs.
and shan, please define what baleted means
edit: this made me lol
Edited by GTR-boy
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
