MODIFICATIONS:
BODY:
* Custom purple metallic paint
* 20in rims with no gutter rash and 90% rubber
* Custom fiberglass front guards 30mm wider than stock
* Custom moulded flares over rear wheels
* Custom bodykit
* Full custom interior, purple suede and white leather everywhere
* Fully adjustable kei office coil overs. (rears just rebuilt)
* Autometer boost and volts
* Nardi steering wheel
* decadent lashings of ghey
ENGINE:
* Fully rebuilt to standard specs (no reciepts)
* HKS FMIC
* Hi- low boost switch (8-15)
* Ball bearing turbo
* 3.5 inch turbo back exhaust
STEREO:
* Pioneer head unit
* MTX 6" splits with tweeters in doors in custom pods, and in parcel shelf.
* 2000 watt boss amp
* 2xMTX 12" subwoofers in custom made box
* Stinger volt meter and capacitor
* DVD player
* In dash LCD screen
MODIFICATIONS:
BODY:
* Custom bodykit
ENGINE:
* HKS FMIC
STEREO:
* Pioneer head unit
* DVD player
for an extra $20 you can have my aids
it was necesary
Hmmm... Thinking about buying an R34 GT-4. How easy is it to do an engine swap? Drop in an RB26 and it's essentially a GTR..
Never seen a GT-4 for sale until now. $15k asking price.
sedan?
theres a build thread about it.
guys ripping out the na stuff and stuffing it full of GTR goodness
edit: oh and thinking about what shans been saying. i guess i realllyyy shouldnt go for a high maintenance car that needs a shit load of work like a datsun. thanks dickhead :D
Edited by GTR-boy
Nah, it's a coupe. Red. Nismo kit. Just how I like my 34s :/
not quite that easy... there's a fair few expenses
Well forget the RB26. Just say I dropped in an RB25DET and made the car into a "GT-4+T" :D
I have no experience in Skylines, I only know MR2s.. but I'm guessing like $3000 for the engine. Another $2000 for labor to put it in. Then bigger brakes and stuff would probably be an idea.
Can you explain what you mean by "a few expenses"?
Edited by jezza boii
The engine will need to be from a stagea or a gtr or it will not fit. Well the sump wont anyways... If you think the engine and labour is going to cost you 5 grand your underbudgetting pretty badly.
landed in malaysia saturday night, place is nice as, few tuners around lol mainly civics/ accords, toyota yaris/echos, every second car here has rims and hids lol.
outside my hotel was m5, porsche 911 turbo & a porsche gt2 or3 which was mint.
Fair enough. Nevermind then :D MR2 turbo it is then.
Jizzy boy, you'll need an AWD engine for ease of transfer, but even then you'll have to change the ECU over, possibly some wiring, while you're at it you'll need to upgrade your brakes if you wanna have it engineered... oh and you'll need to get it engineered if you wanna stay legal. Not to mention it'll be an auto, and making it a manual is about the hardest swap you can do cos your choices are "R33 S2/R34 GTR gearbox", or "R32 GTR/GTS4 gearbox plus a lot of messing around".
If I were you just make mad cash moneh by selling it to some P-plater stooge that wants to jump the cool car bandwagon by buying a heavy ass non turbo. The moment you turbo it, it'll drop in value.
In short, DO NOT BUY AN AWD SKYLINE unless its a GTR. Trust me, I own one... and unless you're gonna be happy with it the way it is for as long as you have it, don't buy it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
