Hmmm... Thinking about buying an R34 GT-4. How easy is it to do an engine swap? Drop in an RB26 and it's essentially a GTR..
Never seen a GT-4 for sale until now. $15k asking price.
As what Shan said...
You could probably get a R32 GTR for a similar price of a R34 GTT.
Or save your money and get the MR2 Turbo.
Yeah I think I will get a stock MR2 turbo. Less cop hassles that way.
Also thinking of getting a shitbox Celica for like $2000 and save all my money for other things (not necessarily cars).
I might take a break from the car scene... We'll see what comes along.
Get an R32 GTS-4 and be a winner like me :ermm:
mine's for sale if you want it.
can supply with stock go fast bits or not depending on how ethnic you get and try to haggle.
comes in 6 different body colours simultaneously.
two owners since new with full books. both owners liked teh go fast pedal.
hahah the abs f**ked up on my gts-4... sounds like someone has had the 4wd fuse pulled out for too long, or has been doing rwd keybangers
mine f**ked up soo badly i coudnt even turn a corner, it would just lock the attessa half way between and it was like jaming the breaks on while trying to perform a u turn hahaha
nah mine just has one caliper locked permanently. It compresses, but then doesn't flow backwards. Guessing there's something in the ABS lines that's acting as a one way valve. Gonna bleed it n see what happens... just need to get around to doing it.
Err.. Your manual comment is void because I CAN drive manual. Would you like to see video of me driving my workmate's MR2 tomorrow? Major inconvenience but I can do it on my lunch break. Would be worth it to prove you wrong... :(
FYI, I don't want to have internet arguments. They're gay. So after this reply just leave it kthx.
Oh and I have driven SAU people's cars before. First one I ever drove was Chad's 32 and he will back me up if he reads this.
If I managed to handle that clutch I'm pretty sure I can handle a standard one :(
If I managed to handle that clutch I'm pretty sure I can handle a standard one :P
wow panties in a bunch, post up saying you don't like internet arguments and you keep goin on fb and SAU :P nice.
lol standard. yes :(
never go into first gear
only go into first gear when you are stopped
if the vehicle is moving, the lowest gear you should select is 2nd
again this would be from sub 30/40km/h
you dont need to downgear in sequence but dont go from 4th to 1st or 2nd
theres too much ratio difference. if your in fourth and slowing down, goto 3rd and brake a bit
use both to slow the car down. not one. if you stick with using one (ie engine or brake)
when you need to emergency stop you wont clutch in, which will mean the car wont stop for peanuts
in an auto when you brake, the engine is disengaged from the clutch, so you stop normally
if you do the same in a manual ,the car will pull up heaps slower and take much longer, cos the engine and clutch are still engaged. ie like slowing down a spinning wheel whilst someone is still pedaling behind on it (on a bike)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
