ive had my 33 for 7 years now
it's done 23,000 each year since i got it
broken radiator
coilpacks died
alternator replaced
diff is grumpy
usual wear and tear - clutches, tyres
37% more power than stock and held up pretty well considering
hehe. I'm in a similar situation but not. I've had my Pulsar for 7 years. Done a bit less than 10,000kms per year as it spends most of it's life off the road.
I've broken well...EVERYTHING.
Should be making 200-210fwkw with the manual behind it. Bit of an increase over the 50fwkw it had stock.
Well done :domokun: That's impressive!
What's it like having so much power at the front wheels in such a small car?
What brakes have you got on there? Stock? Coz if so then I know what you mean by 'stopping is the hard part' ;)
Sort of stock. Front and rear calipers and disks upgraded to SSS items (single piston, but a fair amount bigger.) The car came with a drum brake rear end and piddly little front calipers stock. It could do with better brakes but they still pull it up okay (even from 200kmp/h+) and I have other priorities.
Poles help?
Arse :laugh:
Poles stop cars very quickly, much more effective than 8-Pots :D
web development, I'm guessing its the same thing Pat's goin for but a more junior role?
nah mines for a graduate engineering position in a flexible plastic packaging manufacturing company. (beer wrapping on 6packs and cadbury wrappers etc)
The tests were pretty lol, the maths questions were overwhelming haha
Ah well, will see what I got next week and if move to 3rd stage which is another interview zzzz
i wouldnt stress too much re: getting the answers correct
i mean obviously there is merit testing your technical and maths etc for general assesment
but sometimes they give you bullshit ones where there is no correct answer
they do this to see your lateral thinking and problem solving tactics, even though there is no correct answer
ive done this a few times when interviewing techs, give them a problem and provide multiple choice where all the answers are wrong
the guy who stands one is the one who scribbles near it trying to debunk the correct answer and goes on to discuss the possible causes etc, the ones you dont want just circle an answer or leave it blank
lol at men in black.
Yeah, will see how it goes.
On another note, my dad blew up his mitsubishi express van engine.
Does anyone know where to get a replacement engine or another van? I see hundreds of them on the roads yet there is nothing on ebay, carsales, carpoint, autotrader.
I guess people selling them are old tradies and dont bother advertising online.. Where would be the best place to search for these vans? Probably notice boards at pubs or something haha
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
