Check out the drop down options on the top right of the screen
Ah thanks!
Only happened to me a few times but it changed the lay out automatically...
Back to standard now, thanks again.
couple of kiwis came in.
they wanted to set up a shop. at first i thought they were f**king around.
one of them looked at me, smiled and said. "oi wld loike to gether som iquipmnt to opin a fush n chup shop"
it was fkn hard not to laugh..
worst attempt at a kiwi accent in txt ever...
loike is more aussie... its more u's in things then anything.
ie. luike, guther, aquipmunt, opun... the fush n chup bit is spot on.
dont ruin our language by making it sound westie aussie
sorry bro..
just tryna write out what i heard bro
Sup Justin.
Took it for the RWC today... booked in on Monday morning for the Reg. We're lovin it... awesome vehicles. The 19inch TV/Monitor came today and i am really starting to wonder how the f*k the installers are going to get it in, its way more massive then i imagined... guess i should have measured it up first.
Nah havent played the 360 in about 2 months... since it died lol
I pulled a plug out on the power board and it knocked the 360 plug out and as i was fumbling around with the power cord it made a nice zap noise and died :) Been playing the PS3 in the meantime. Going to buy another arcade model and mod it soon.
Hows things?
At the moment I'm missing renting where I was able to tell the landlord that the hot water was broken and they'd get it fixed... now I have to get it fixed myself, and pay for it, doh.
Currently waiting for payrise - due in march, no idea how it will be yet. All the good jobs available at the moment seem to be recruiters trying to get people for us anyway... sucks that contractors get 3 times what we get for the same work
hahaha yeah owning a house has its ups and downs... still more ups tho.
ie. mine is now valued at over 100k more then what i paid for it 4 years ago... cant really argue with that.
What do you do Justin? Its funny cause here the contractors dont really get any more then perms depending on their role.
NICE!!!
Post pics.
My friend just bought 1, just last year, took it for a spin and it's great.
The VQ35DE really pulls.
Yeah i will once its reged and ive put the LED tail lights in.
my wifes is only an early model E50 so it has the VG33E... still pulls pretty well considering how much those things weigh.
Awesome!
Love the E50's.
So you got the 3.3lt V6?
Which level of Elgrand did you get?
- Caravan
- Homy
- Highway Star
- Rider
Did you get a factory body kit / aftermarket wheels?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
