you should watch Law Abiding Citizen (if you havent already), i nearly had a heart attack when the judge got killed off lol
mm fair enough
i guess ill get it fully checked over before i buy one.
on another note:
went and saw wolfman
since i get scared very easily, i was shitting myself
but it was pretty good. epic fight at the end
haha i have. yeah i nearly fell off my chair
but mates were literally crying of laughter at me. i was shaking... because of the start..
and to think my mate tried to get me to watch paranormal :)
lol, awww. thats so cute tho!
I really want to see that
did anyone go and see paranormal activity
it was supposed to be like the most scariest, freakiest, movie EVER
but............................. its not real..........................................................
how pointless...............
:thumbsup:
this is a must read he says its a gtr lookalike, it has the gtr badges and also he states it turns heads and most people mistake for a gtr lol.
http://cgi.ebay.com.au/NISSAN-R34-SKYLINE-...=item20af801039
edit: i just noticed it says that it never gets thrashed or drifted like most imports do and his username is ozzydrifter lol, not saying he does drift it but it just looks funny.
as for that GTR look alike it doesnt even look like a GTR and it turns heads cos its an fugly pos that should be crushed.
fkn NSW'ers and there sexspec failmobiles. and dont even get me started on the offset fail *facepalm*
That shits a mutha fucking fail and a half!
:thumbsup:
Morning!
Why's that?
Hey!
It's Esther from NS!
Hehe!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
