oh man troll'd. Almost as bad as that green or purple R33 that someone linked to a while back.
hellaflush is overdone, get rims that sit IN your guards then stick flares on like cool dudes do.
alr33x you should cuddle and reacharound with Mad082 he also baaaaaaws about the "old" days in the wasteland
haha check out my front pop-down spoiler :D and you all want me to bin it to fit in a larger cooler
http://www.photoshelter.com/c/jrmphotograp...0000mvqskgMirJs
looks different
keep it
on another note
my best mates ex is coming onto me
my best mate wants me to crush her hopes n dreams 0_o
yeah he is a total queer dog, he seriously likes magnas and R33's LOL.
Hellaflush is how most lowered IRS Commodores sit you know :D
I'm soooo getting some adjustable control arms for mine so I can eliminate it!
that statement confirms you have no idea what hellaflush is.
oi gtr boy i made my e/n thread for shite like that in the wasteland check it out brah
R32 Auto Spoiler is teh sex, don't listen to the monkey, he's too hellaflush for his own good!
Rekin bash the cooler like I said :D luurves it
llama_au : i am SO jealous. 2way?
on another note
bro's before ho's. tell her you'll only ever accept her if she takes it exclusively in the pooper. if she agrees, then win, if she turns you down, you're doin well by your mate.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
