cameras break when pointed at his cars
this is true. also you need wide angle lenses to pick up the trail of parts that fall off em.
I'm sure my ceffy has pics in the ceffy section. do a search for "godfather bitches".
for someone who's apparently only ever owned run down pieces of shit, I've always sold my cars for a profit.
even in this ghey market its not hard to find some nooblet who doesn't know how to spend wisely.
his car is his keyboard didnt you know? :thumbsup:
if i new how to make a signature that would be sig worthy reply of the year.
sif blags green on white i secks u seen the guy @ winton with that setup its hawt :thumbsup:
buy. a. car.
any. car.
now f**k off and die.
i do have a car funks.. its just not worthy of tuff fitment etc so its for sale
Yea true. I'm dreading the day i sell mine. Owes me about 30g I will struggle to get 17 lol. Guess I can take the mods off. Never know a PFC soon might be 2g second hand haha
Talk to me when your car is worth less than 1/5th of the money you've spent on it :thumbsup:
meh just keep it selling it is pointless lose a fortune, i sold my first skyline did my knackers this time did everything cash so whatever happens to it i dont care worst case ill part it out once i destroy it.. the imports market is fkn gay for resale which is great if ur buying .. i rang ppl up just said ill give u X no.? ok hang up next guy and so on till someone said yes
I lost on mine, but considering what others were (and are still trying) to sell their cars for, I did pretty well....
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
