Rekin, if you had rolled / flared your guards, you would have been fine.
See what you get for running mexican fitment Pat?
haha true
Chucked on the stockies on the car. Reversed the car out of the garage and scraped the freshly resprayed bar pretty badly. Going from the 17's to 16's lowered the front of my car just enough to bottom out :)
After defect cleared, gonna get the guards flared and dial in some camber. Sitting at -0.5deg on the rears. Might go for -1 or -1.5
Although what I have learnt is that you need to leave some crumbs for the cops. Else they will keep searching until they find something really hard to fix like a turbo, injectors, tune or window tint
looks like a S13 for starters.
man this iPad blows baby goats. The user inteface is nice n clean and slick, but the moment you load it up with features in an app or install more than a handful of content rich apps, the shit just slows right the fuck down. its so closed off as well... like... you can't print anything off it. which kinda sucks, that's one of the first things I wanted to do on it. Maybe use it to access photos I took with my camera... its got a great photo management and display app, but no way of getting any decent pics onto it straight off my camera.
fuck this shit. I'm buying an HP Slate when it comes out. That said.... free iPad how can I say no? :thumbsup:
that looks like a mega full cage... 2 cross beams in the back and no back seat.
the widebody kakimoto 33 runs a cage that has 2 loops that go into the rear seat, but it's still useable. Does that help? I can get you pics of that.
www.paulr33.com
unlimited everything quota, space, mailbox, features etc
$5 a month charged on a 2 year contract www.justhost.com
hmm, definitely sounds better than my 60 a year, quotad, limited hosting that drops out quite often... really must swap next renewal time
funky you know your iShit yeah?
sent my iphone off to be repaired/replaced (f**ked it up real good so hopefully replaced), but I wanna know if
A) when I get the new one, if I connect it to my PC and hit restore in iTunes, will it restore all the shit from the last sync/backup of the other iphone, and get back all my messages/apps etc...
and b) if the answer to a is no, is there a way to access any of that stuff through the backup files that itunes would save somewhere when you backup/sync the phone?
Anyone bought a modified car from interstate before?
I'm wondering if it would be hard to get registered.
This is seriously tempting me...
http://www.carsales.com.au/all-cars/privat...MR2&trecs=4
Edited by jezza boii
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
