was looking at that yesterday...lose the 34 GTR wing and it'd look a lot better...
I agree. I don't think the wing suits.
Other than that it's a pretty sexy car :ermm: Just a shame that it's out of my price range.
So whos going on the cruize over the black spur? this weekend. I'm considering it
Considering it if I am not doing anything else.
LOL!
+1
lol poor man's R34 NUR.
even got the N1 vent, paintjob and all.
:ermm:
Millennium Jade is only meant for R34 GTR's.
Same with the R34 GTR spoiler, only meant for R34's.
I don't mind millenium jade on the 32. "I'm highly offended" by the fact that the dude's tried to make his 32 exactly like a NUR, by fitting the vent and wing.
R34 Turbo's + Brembo's + Millenium Jade = win
R34 Turbo's + Brembo's + Millenium Jade + N1 vent + 34 GTR wing = try hard Nur = fail
What N1 vent are you talking about?
You mean the 2 in the front bar?
I just noticed the R32 GTR we are talking about has a shaved boot / no key hole.
Junior Wing Suite:
Ah, ok...
Looks nice!
On the bonnet. V-Spec vent? N1 Vent? Whatever model it is that came standard with a NACA duct on the bonnet.
Ah ok I am with you now!
I thought you were refereeing to the R32 GTR jezza posted and all I see is a HKS style vented bonnet.
Yeah I know what you mean.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
