Did you say your singer was off AUS Idol?
Sounds like he's in it for the money and fame rather then the love of music... That's how I see it, I could be wrong...
In all honesty, I would not approach anyone from AUS Idol or AUS Got Talent shit but that is just me.
Is he a good singer?
Yeah, he had a shot in 2006 (when he was a bit younger and less experienced). Made it into the top 100, flew to Sydney etc. but didn't make it much further.
Then he sung/played guitar in front of 10,000+ people at Youth Alive for a few years.
Now he plays guitar in punk/pop rock band "FIDO", runs Grafete Studios and teaches music... So yeah, he is very busy. That's why I said he would probably only do gigs for $$ (coz it would probably mean dropping other projects).
He is a very passionate musician and a huge inspiration to me. When he agreed to sing/produce my project I couldn't believe it.
Sounds good!
See how you go.
bubbling paint on the walls is a bit random, but re-painting is pretty easy
im almost done my house, just got one roof section to do, all up nearly $1100 for everything, so just kitchen will be cheap
I think they must have used the wrong paint and the dampness is making it bubble (no extraction fan + cold climate)
Thinking of repainting the cupboards at the same time, currently they're pooh brown
He's booked months ahead of time for gigs all over Victoria, and has his own singing school
Wow, fair effort. After the hype dies down most idol contestants go back to their day job :P
What is your mate's name?
well that was my first day off in over a year, i have another 4 more days left and im already sooooo bored, i hate it.
here are some vids ive been watching lol.
why rev it so much before take off? its not like he's at a set of lights
63k when he bought it! LOL, 60s are the magical number for dealer imported cars, they must search the auction lots for cars in the 60k range. Its amazing there are still so many cars out there in Japan in the 60 range! Maybe everyone stops driving at 60 odd.
No offence to the seller, i'm sure the car is genuine, but.........anyway, doesn't matter
could be the fact to that by the time a lot of the 32s hit 60000km the registration was to expensive for them and a new car was purchased (as it goes itn jp)
but eitherway you have someone like stateroads check it and they will be able to tell by the bosy/interior etc condition if its legit
my mate just bought a xr6 turbo ute and damn they are very quick cars.
the funny thing is he bought it from queensland got it checked and stuff and they said the clutch is on its way out but everything else is perfect. he flew up there and drove it back, once it warmed up the clutch kept slipping until he got into nsw and it went so he had no clutch for the rest of the trip to melbourne lol. and he had so many bugs splattered on the front and stuck in the intercooler it was hilarious. he said next time he will get it transported down lol.
i dunno when you buy cars you wana drive them straight away
id look for one with everything working
Yeah but at that price, if everything else checked out, a new clutch and you're away for well under 20k...
As for the kms, 99% of the time they're gonna be bullshit. Again at that price, if/when the engine lets go you rebuild it.
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
