I had no power steering in mine for a few weeks. It doesn't bother me that much :P You get used to it and don't notice eventually.
My workmate has no PS in his MR2. Has gone without it for 15 years and loves it like that.
Also, less weight :thumbsup:
When you're moving faster than 10km/h there is no noticeable difference IMO. The only time it's a bitch is when parking.. but you just let the car roll a bit and it's fine.
Like I said, you get used to it :thumbsup:
chuck G-Parted boot disk in the drive, plug a USB hard drive in, turn it on, when it boots into the UNIX recovery OS, launch file browser and copy your files to the USB drive.
Then move it to a new computer or try and resurrect your old one.
There is already a disc in the drive and it won't eject :( Any ideas how to get it out?
finally burning some new music for my car
over the radio and the same cd ive listened to for about 8months
my car has alot of cd's in it, but they are all burnt, i keep the originals at home. atm im listening to nofx. no doof doof music ever in my car, only punk rock :(
I had no power steering in mine for a few weeks. It doesn't bother me that much :whistling: You get used to it and don't notice eventually.
Also, less weight :P
I've had no PS in my Commodore for about 6 months it works every now and then which is a real pain in the ass, the wheel moves too much when you expect it to move only a little. You do get used to it though, does give you bigger forearms though :(
hey fag i sent it through
just printed it and noticed it needs your name and sig n shit. thanks anyway.. ill check if the importers near my school have anything.
i wonder if they would approve it even though im still on my L's
oo i got a reply from Recochem
200Ltr drum of 100% denatured industrial ethanol = $437.25 + GST
Equates to about;
$6.60 per week (3Litrs/week)
$3.00 per week (3Litrs of dimineral water/week)
$9.60 per week
Now is this worth the 30-40kw atw gain O_o
my car has alot of cd's in it, but they are all burnt, i keep the originals at home. atm im listening to nofx. no doof doof music ever in my car, only punk rock :P
not a fan :(
hmmm why my name and sig? If your the one that wants the car to be able to drive
the person that ownes it is only selling it
Equates to about;
$9.60 per week
thats on a 60litre tank though
the evo only has like 47 i think and only about 40-42 is used when driving before the fuel light comes on
so works out cheaper if i do it :( haha
not a fan :(
fair enough everyone likes different things. what music do you listen to?
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
