Just making sure you know that CAMS approved half cages are rear half, not front half.
http://www.camsmanual.com.au/pdf/10_gen_re...dule_j_q210.pdf
of course its rear half.. why would i get front half :)
yeh its approved and shisss it seems steep but aint no1 else got them that i can find. this guy wrote the RWC manual on roll cages so he knows his stuff at least, not that i care overally im a defect waiting to happen :P
902 is unfitted to but probaly chuck it in with mates
i do, i get along with most people on here
yeahh i try not to offend anyone on here.. wouldnt be good
although i do hold a grudge against shan for changing my username to ladytron ages ago...
kent :P
For reference, I payed $950 for a half cage, with harness bar fitted in my 180sx from BD. Mind you it was about 2 years ago now though.
Since when aren't bolt in CAMS approved Shan?
I had a half cage bolt in from Brown Davis, and it came complete with CAMS paperwork and never got pulled up with scrutineering.
alr33x:
Their work is awesome, so I highly recommend them, but they need a few lessons in customer service :P
since the 2005 handbook (section J) from memory (I could be wrong haven't looked at it in a couple of years). depends on the event you're competing too, half cage is fine for speed events, but for rally etc you need full cage.
Also just cos its CAMS compliant doesn't mean it is ADR compliant. Guess it all depends on what you want the cage for? street or track?
thanks man
its for drift events and street.. according to BD its fully compliant and street legal but meh.. doubt mr.plod will listen to that anyway was just wonderin about price and if their stuff is decent more so.
to get from japan will be 1k++ easy plus i was told streeter doesnt do cages so then gotta go to importer who will wana make a cut as well :P
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
