be careful with shit cam gears
Racepace used to get them made locally at a fair price, not sure if that is the case these days. And that's only if your getting Racepace to work on your car.
Check with your tuner before you buy cam gears :)
im sure if done well a pump would work....
check hellaflush, i'm sure there'll be an example on there :)
had a look and there is only one black one running tuff fitment, but the way its done makes it nice
just puttin it out there best evo ive seen.
mmm i like sp1's but jsut not on an evo
needs a racey sorta wheel i reckon like te37, xd9, xt7, ce28n
Put some 34 GTR's on that mofo Nick! But chuck some spacers behind it too = mint!
I'd love an Evo 6 with 34 GTRs
yeah they expensive though, like the cost of the xt7s or cr kai's will be cheaper than the 34 gtr rims
and they need the centre hub machined out to clear the hub on the evo
however ive seen a blue evo 6 and yellow evo 8 both from interstate running them without spacers and it looks hot
depends teh look ur goin for... if it was me id be going that sleeek cruiser look like the black one but u still know it means business
the ones u posted are good to but are more in your face "im fast, racer boy" which is cool to if u like it
white bottom one looks best imo.. that second last pic bolt on flares or whatever it is.. yuk
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
