my professors (18x9.5) are just on 10kg
they aint heavy wheels
call him and tell him your a mate of mine.... then watch him drop $50 of the price like that... LIKE THAT!
whodaman?
I had about an inch on you, now with 17's its about an inch and a half lol... Lets not go there!!!!
When I get back, ive got something in store for you ;)
are you sure..? haha when u get back july or soemthing?
Oh and alex, nah im not coming tonight haha. How was/is it? same shit or...?
didnt go.. was to warm in bed haha.. think it was usual shitttt been a bit better last couple weeks but a bit more attention too it seeems :down:
Yeah cool Shan!
If they want decent resale value, then yes... Yes they do :P
that aside, regardless of ur personal opinion of gtrs, they're still an icon. Kids grow up lusting after it and staring at it. Not that they don't at other skylines but it has a rep that's hard to shake. My bf's gtst makes 280rwkw and is bright orange. And it gets a lot of attention. But my stocker 190awkw gtr gets just as much awe as his does depending on the audience. First question when people see it... 'is that a REAL gtr??'
And his car as a 34 is still 40-50k 10 odd years on.
Case closed :D
Fuck I hate it when ppl ask that!
To the untrained eye, they can't see the wider guards and the GTR badge.
What makes it worst is, I don't have the OEM Spoiler and ppl just think it is a GTS-T.
Garage Cafe Audi S5..?
why don't you e85 tune it while you're at it?
in other news...
Regamaster induced boner:
:down::D
I like!
Well it turns out that the oil light was only on because the sensor is from the gen2 NA engine.. the gen3 turbo is completely different.
That's what the previous owner told me (after I just txted him about it).
I actually checked the dipstick this time and it indicates it's full haha..
BUT there is a pool of oil under the car (probably about 100ml). Could this be because I overflowed it? I only topped it up by about 100ml
Either I have epic failed or the old owner is lying.
so originally was a gen 2 NA engine ? and now a gen 3 turbo
why the engine swap?
Well the swap was done at 220,000km when the old engine was getting a bit old.
The gen3 is a much better designed engine. And well, obviously for more power!
Gen 2 NA = 117kw
Gen 3 turbo = 180kw (stock)
Mine would probably be over 200kw. Loving the power/weight ratio :down:
Gen 2 NA = 117kw
ah yeh fair call
yeah i knew they had more power, and they dont feel so restrictive up top cause they have better cams (brother was looking at buying one)
actually when he was looking he found a gen 2 with gen 3 engine we test drove in gladstone park, was red and paint work wasnt the best best
sounds similar to the one you bought
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
