imagine these on a GTR...
porn wheels
f**kin want
also
can you get pearls in a spray can?
FB 1/10 scale shell is finished, just needa get it perfect and prep it, then paint it a pearl blue.
Edited by GTR-boy
porn wheels
f**kin want
also
you must have aids.
that shit be hideous and on a gtr... broady spec!
your seriously f**ked
go by a f**ken commo and put that shit on
nah bro, they would look sick on an R32 GTR.. imagine it dumped with those
edit: OBVIOUSLY trolling haha... imagine if funky saw that shit.. he would hunt me down haha
Edited by GTR-boy
check eddititited post..
btw, i think they would look good on the evo. its already "bt1" yellow, just needs tan retrim
the edit was to late, we know u got teh aids now
might be yellow, doesnt mean its thommo spec vl stylez though
take this advice.
pls.
edit: does it dose? then its thommo spec :D
i live near lalor, go to thommo reguarly, and really. more VT's and VS's around here now.
everyones getting XR6's so their kinda the new VL turbo
and no, not moving to sydney, f**king hate sydney and anyone who comes from sydney.. thats right, i hate my mum
you still fell for it :)
do 22's even fit on an R32? lol
nah i know u were joking
dunno think someone had 20s that jsut fit still :D
more than just v8s in thommo
lots of xr6 turbos and even nissan patrol turbos and shit
like Alex said, if it doses its most likely from thommo
should be able to - take a paint code to auto paint store and ask for an can o' acrylic
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
