spotted blags doin laps for school girls :P
You looked like a cute little school girl, I blew you a kiss lollll
I was actually going to the post office to ask about a TravelSim card, lady was useless even though they do sell them. She knew nothing about them apart from the fact they were sold out haha
does anyone know what year r33's were first available here in australia and how much they were?
an R33 GTSt cost $40k in 1996. They were available for import since early 95. They started production in 93 in japan.
I paid 25k for my 180sx in late 98. me and a few mates felt ripped off, so we started J-Spec :P
Bought my first skyline in late 2000, met up with PranK etc (when I used to live in syd) decided to form a cruise club... called it SAU.... well first we called it Hybridz, but then we called it SAU :P
fuuuu turns out my GTR injectors are leaking. Time to replace all 6 with some brand newies
Who know anyone who can get injectors asap? I have track day on June 6th (looking like im not gonna make it :P )
6x Denso 550cc injectors GTR - $165 each
Anyone know any decent GTR replacement injectors? Im after 444cc
All my wiring is setup for GTR injectors, so they should be cheaper than GTS injectors hopefully
Need them asap
Found some Sards
http://justjap.com/store/product.php?produ...=310&page=1 - $999
Anyone know any Bosch injectors? Have a friend who could hook me up with staff prices
Cheaper from companies on ebay
not bad
http://cgi.ebay.com.au/SARD-63500-700cc-FU...=item335d4f7864
Why are the 700cc cheaper than the 550cc lol
haha, that is a bit odd - I only looked at the price on the 534ccs
:bunny: see ya tonight!
I paid 25k for my 180sx in late 98. me and a few mates felt ripped off, so we started J-Spec :(
Bought my first skyline in late 2000, met up with PranK etc (when I used to live in syd) decided to form a cruise club... called it SAU.... well first we called it Hybridz, but then we called it SAU :wub:
who asked for ya life story? :(
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
