What's wrong with those plates? I think they're pretty clever :banana: JDM MR2 or JD (my initials) MR2.
Most people were supportive of my choice but eh, can't please everyone :banana:
there is nothing wrong with them its just they are not funny, while 'jizz boy' on the other hand lol.
nah they alright, but JDM MR2 doesnt suit cause its an ADM car
:banana:
I know :bunny: Ironic eh? But I decided about 2 years ago I wanted those plates. Mum eventually bought them for my 21st.
At the end of the day, ADMs never came with turbos. Only my friends will know that it's not an import.
Only the shell is ADM. Everything else is gutted from a JDM model. The wheels will be JDM. All performance parts will be JDM. There will be nothing aussie about it :D
except the Vehicle identification number
With that view you could say that a gtst with a GTR bodykit and rims is a GTR /troll
Would have to have a GTR engine and AWD system :bunny: Then you could allllmost call it a GTR.
Mine is identical to a jap model. Good luck finding anything that says otherwise :D Other than VIN as you mentioned.
ceebs doing it properly, you get the point haha
An oldie;
Last month a world-wide survey was conducted by the UN.
The only question asked was:-
"Would you please give your honest opinion about solutions
to the food shortage in the rest of the world?"
The survey was a huge failure because of the following:
1. In Eastern Europe they didn't know what "honest" meant.
2. In Western Europe they didn't know what "shortage" meant.
3. In Africa they didn't know what "food" meant.
4. In China they didn't know what "opinion" meant.
5. In the Middle East they didn't know what "solution" meant.
6. In South America they didn't know what "please" meant.
7. In the USA they didn't know what "the rest of the world" meant.
8. In Australia they hung up as soon as they heard the Indian accent.
nah, if he does the car propper fuckin JDM then i'm willing to pay it
i mean JDM could mean the car is from japan OR it is modified in a JDM style
course mine means both cos i'm rad like that :bunny:
GAHHHH So to my surprise this morning when going to my car is a nice pool of coolant on the passenger side, So i take it my heater core has given up.
So where can i get a good condition heater core. and a guide how to remove the heater core.
shouldn't it be JD'S MR2?
It could be, but it's meant to be a play on words.
nah, if he does the car propper f**kin JDM then i'm willing to pay it
Are those SSR's you suggested JDM enough? :D
What else do I need to make it "proper f**kin JDM"?? :bunny:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
