niceee mx5.
hows your's goin hamish?
the funds are failing me at the moment :D
will have to sell the rolla to do it, but I'm gonna spend some time slidin it first
need to learn to properly drift an underpowered car
with 300rwkw you don't learn to drift properly, you just learn how to wrangle a wild horse
Hard work is the point lol
the rolla is nearly finished so I'm in need of a new project
an the mx5 will be somehin I can daily with no EPA worries apart from exhaust
I can just throw in the stock suspension and zorst and clear any EPA and have a baller daily
That's why I was so confused :D
Hmmm... I need bigger brakes. Not only do these brakes fail to stop but they'll also look fail when I get my SSRs...
I would put my TT Supra calipers on but people tell me it's not worth all that extra weight.
Edited by jezza boii
haha... yeh since i repainted them they look awesome.... and the braking is wayyy up there, especially coming from the 32
if you get a little more power you only weighing it down what 20kgs? max for the whole setup extra.... worth it for better braking that doesnt cost major bucks
woot. just bought a brand new unpainted OEM VW golf MK4 R32 kit.
now the question is, should I get the optional MK5 GTI style front bumper or should I get the regular MK4 R32 front bumper?
MK4 R32 sides and rear:
MK4 R32 front:
real MK5 R32:
same style but for an MK4:
probably should just stick to MK4, cos putting a MK5 front is a lil wanky like R34 fronts on R32's. Mind you there's not that many guys no one who've done it.
I've just posted a thread on MR2 forums asking their opinion.
I could probably get late model turbo brakes for fairly cheap. It just sucks not having ABS. Push down too hard and it just locks up.
I guess with bigger brakes I won't have this problem.
Hmm.. What cheap mods can I do in the mean time? :D Just little shit. Like I just bought NeoGauge dash LEDs for $17.
Finally an excuse to rip my dash out again :P
stop wasting money you don't have on pissy little gimmicks.
$17 isn't exactly substantial.. In fact my workmate payed for it using his Paypal and hasn't even asked me for the money yet :D
I just want to do work on the car but there's nothing to do...
i prefer the mk4 looks cleaner and will suit the look your going for
bigger brakes will just lock you up harder. learn to let go of the pedal when you feel it locking up and then reapply pressure... that's what ABS does anyways, just stops you from stomping on the pedal like a full retard.
Won't the extra braking force increase the problem?
My mate said otherwise. Can't remember what his reasoning was though.
Wouldn't it slow down quicker without having to really push down on the brakes?
Confusing shit lol.
Bigger calipers dont help you stop quicker if you are running shit discs (small). Will just have a quicker lock up effect like funky said.
You need to have bigger calipers and discs for it to brake better.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
