If you're already locking up, increasing traction will help. Wider tyres.
Yeah, I forgot to mention that I had balding fail spec Nankang 215 tyres on some TTF 7" wide rims :D
But never fear, thanks to Hamish I have got those SSRs on the way. 8" front and 9" rear.
Should get a 245 on the back. That will definitely help.
... or just don't jump on the pedal so hard and pulse your braking.
costs $0, and it level up's your driving skills.
Well... It's only happened ONCE. And I learned my lesson. But the brakes still get to that "locking up" point too quickly. I can feel it.
Was pretty funny when I did it. Middle of Nepean Hwy in traffic. Made a big amount of smoke. People looked at me as if I was retarded.
Pretty embarrassing :D
woot. just bought a brand new unpainted OEM VW golf MK4 R32 kit.
now the question is, should I get the optional MK5 GTI style front bumper or should I get the regular MK4 R32 front bumper?
probably should just stick to MK4, cos putting a MK5 front is a lil wanky like R34 fronts on R32's. Mind you there's not that many guys no one who've done it.
huh? why are you searching for a front bumper when you have already bought a 'kit'?
i say go MK4 all over, that silver r32 with the black BBS rims looks porn
cos the kit can be supplied with an R32 front bar, or MK5 R32 style front bar. Same price, 100% polyurethane (no fibreglass), fits perfect etc. Gotta love aftermarket parts out of Europe... none of this half arsed stuff like jap aftermarket parts.
Yeah consensus seems to be that MK5 R32's should only exist on MK5's and not on MK4's. Pity no one's done it before (or if they have they've done some gaybo fibreglass conversion that looks shocking) so I can't tell if I like it or not.
so you have no idea what the mk5 front will look like on the mk4? sounds risky
nope. I know... that's what's shitting me... the fact that I can't visualise what it'd look like. Otherwise I'd have made the call and gone for it.
Pat spending money? I don't see that happening lol
On another note;
My engine fan has been replaced with a thermo fan due to the larger radiator.
Anyone know a good thermo fan controller? Im after one which reads ecu water temp signal, can set trigger point (85degrees) and will turn off when it reaches another set point. (80degrees)
Now go :D
You fan should run off a thermositor. Figure out if you can tap a frequency or voltage line coming out of it and then add one of these:
http://www.jaycar.com.au/productView.asp?ID=KC5378
http://www.jaycar.com.au/productView.asp?ID=KC5377
program in the relevant voltage/frequency that corresponds to the temp you want and off you go.
thanks for that, Found this;
http://autospeed.com.au/cms/title_Electron...77/article.html
Has a temp on and cut off. Although im not sure how to wire in that if AC is on that it is always on...
Any chance you know where the 12v Aircon trigger wire should connect on the relay?
Thanks
Same. f**king pissed myself when I got her messages and called her an idiot.
haha
poor guy didnt know what he got himself into
although ironic how many times she told everyone she hated greeks and yet shes with one now :thumbsup:
want me to exchange some eggy gifts? :nyaanyaa:
haha nah man all good
as much as i hate her, i just thought it was f**ken hilarious :)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
