With any track oriented car, the idea is to have proper cooling.
I see... how often do you get on the track then? and no, motorkhana days doing one lap wonders don't count. When was the last sprint or enduro race you entered? Cos a radiator that size is only ever gonna be of use when you have massive heat soak to dissipate. You're running a thrmo fan with no shroud on a street driven car, which will result in pisspoor airflow through the fins in stop start low speed driving.
It's true, I hardpark my daily... ever since I got 3 dents in my daily at deca i refuse to track em. That's why I have a perfectly good stripped out, rollcaged race car sitting at driftline for when I got out to winton etc (running a triple core koyo rad and a couple of thermo fans off some ford)... which is for sale btw, as I won't have a shop to maintain it or time to race it.
What I'm getting at is that making a daily driver into a "track ready" car is an expensive, uncomfortable process. You'd be better off just buying a cheap second car and going balls out on making it an all out track car. Your car's emo enough as it is, the more you push it, the more things are gonna break.
</ethug>
</ethug>
fyi I was meant to have a track day this saturday but pulled out due to car problems and no one said that my cooling setup has been finished. Twin thermo setup + shroud (AU falcon) is the next step, depending on the clearance. (else flex-a-lite low profile thermo setup)
I have a hyundai getz as a backup car, but i will continue to drive my car as a daily and not have it looking pretty in the garage. So all im saying is, dont assume what my car will be used for because it makes you look silly.
The r32 has always been aimed at being a track oriented car because in the future I will be buying new cars but this car will always be sticking around as its not worth selling.
/drunkl
just bought a jzx100 chaser :)
converted from nissan to toyota
dam i miss the 33 still
congrats
pics?
lol? how come. What did you wear to get in?
collared button up shirt
black jeans
wog tappers
we all got asked to leave though.
turns out for every underage person there, there had to be an 18 year old
so we all went to crown and shit
nah weather is absolute shithouse
drinking yourself to sleep would be more advisable
haha told
friday night was great
all day today was crap
had to unload the truck in the pouring rain. i think im sick now
just took car to brakes plus for 2 hours and they have managed to get rid of the brake squeel that the other 3 places ive had it at for long ammounts of time couldnt..
finally 8 months and no brake noise!
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
