just got me some tein superstreets for the gtr.
Glad im not the only one that spent cash today :)
Bought a Blitz SBC Spec R Dual solenoid boost controller to replace my single solenoid blitz spec s one
Also got a blitz lm panel filter
:spank:
:spank:
nice, im glad im not the only one also lol. wasnt looking at spending cash today but these came up at a good price.
Haha yea I'm poor now but I haven't bought anything forthe car for a while so meh why not a $600 boost controller lol
hmm now the waiting game :)
hmm now the waiting game :spank:
yep thats my excuse, i havnt bought anything for this car yet :) . but it was something i needed they said the rear shocks had gone and needed to be replaced. so why get expensive stock ones that were going to be $385 each when i can get a full set of tein superstreets for not much more. now ive got to wait too and not just the suspension im still waiting for my car :nyaanyaa:
Lol I'm just stating the truth pat and agreeing with a true statement is fine :spank:
please show me some evidence to back up your claim then.
Cause I havent seen you at any motorkhana event in the past two years where the car gets plenty of "boosting" instead of your attempt which involves up and down chapel street. :)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
