car got egged last night. didnt look like too much damage last night but i havent had a look in the light yet. little shiiiiits. im gonna put my ciggarettes out on their nutsacks if i find the flamin mongrels
maybe they didnt know you are one of those brothers that can bust a cap in their ass
the only thing niggeroj can bust is his sphincter from being a gigantic fag.
and she will drive the same policies he did
she was the one giving him the policies he did
i think people expect because there is a new leader, all the polices will change / magicaly vanish
hhhmmmm i having strange obseesions for an r34 4door lol
So Juliette wants a Nissan Cube and you want a 4 door R34 Skyline...
Offer a price to Juliette to see if she will sell you her 4 door R34 Skyline and she can use that money after the sale to buy a Cube.
As much as that sounds like a good idea, I still need to drive it for the next few months while I'm waiting for a Cube to land, be complied, rego'ed, etc. I've got a loan to bridge the gap in the meantime. But yes, it will be for sale as soon as the car lands. I shouldn't have too much trouble selling it, there's a lot of people offering to buy it already. She's a good car.
fffffffffuuuuuuuuuuuuuuuuuuuuuu for having the day off. and wtf are you doing up early. its perfect bed time atm lol
nick was driving next to an evo 7 last night told him to launch it so he launched it at limiter lol. sounds hottttt. go outside and do it now
You'd get a good price.
wat happened to the pulsar?
What he said :/
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
