if you want to upgrade BCNR33 dumps, go for a pair of BNR34 dumps
but be prepare to pay for them, they arent cheap
or see if you can find some xforce ones, and do some research on reviews before buying
if you have std turbochargers still the stock ones are probably OK
i would focus on the rest of the exhaust if you have a stock GTR with stock everything else
to me the power with the GTR is in the ECU + tune, Boost, exhaust and the tune (again) the tune is so important
Kris I think if you rebuild gogo RB30DET with a T51 :ninja::D man i love the sound of those things, theres a white GTS-T with one on youtube which does huge powerskids
if its got a 26 head and inlet manifold then yeah
otherwise nothing beats a worked 26 sound
wanna buy my old one? 5K engine only. RWD too. plug and pray.
lol
when you turn 18 and can drive a car then your opinion on the subject will be considered..... most likely disregarded again like now :ninja:
lol based on youtube vids and mad mikes fd rx7, i think they sound pretty horn
are dumps worth upgrading on a fairly stock (for now) GTR? from what i have heard dumps are only really worth upgrading when upgrading turbos is this true? Looking at you Jamie *cough cough* :ninja:
Like what Paul said, your stock dump pipes are fine.
No need to change, unless your doing heavy modded turbo work.
i finally have my new car safely at home. it's awesome, i cant believe how easy it is to drive as well.
Pics! :ermm:
stock dumps are fine for most applications
jezza, in17" you really want a 45 profile for anything around a size you are gonna want, 40 is for 18's... too low profile makes the wheel look mega homo
for my 17 x 9.5's i'm going 235/45/17
Get 235/45/17 Jezza.. commodore size so will be cheap. When you start getting uncommon sizes is when the dollars pile up
ring Tyrepower Hawthorn btw
That is what I am running up the front.
A decent size.
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
