Opinions on this wing? Too big?
http://i48.photobucket.com/albums/f231/mar...r2/img_0711.jpg
http://i48.photobucket.com/albums/f231/mar...r2/img_0709.jpg
They're really rare and one has popped up at a decent price. I'm definitely thinking about it...
they looked a touch yellow when i saw them. was your car near the front door?
yeah it was, as you walk in it was on the left hand side. thats odd because they are definately not yellow or anything like that.
looks fine to me, it looks like the older model wrx rear spoilers.
Was driving down highstreet looking for a carpark at 6pm. Stuck in peak hour traffic. Raging cause everything is a friggen clearway.
Then notice there is a cop behind me.
Moving 5km/h in traffic, waiting for the disco lights.
On goes the lights, and i pull over to the side of the single lane road moving at 5km/h
Cop comes out, says its a "random license inspection". Asks for license checks it, does a bretho and goes back into car. Whole peak hour traffic staring at me haha
Cop comes back, hands me back license and tells me to have a nice day ~_~
End of story
yeah looks alright, not over the top
even if they are, easy fix with headlight polish
End of story
haha
yep, that was it. the yellow must have been the lighting or something
yeah it must of been. plus i didnt think they would go a yellow colour with xenon's? but i could be wrong.
also i had a couple voltage's today from gloria jean's and im crashing hard at the moment.
i got factory xenons...cloudy as. mines a bit older than yours though.
my old r34 was starting to get that cloudy look. i dont think my new one does even though ive only seen my car at night, cant wait to see it at day time lol.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
