get f**ked, it's hilaaarious. even virgin boy thinks it is.
not rly man... not hilarious. just funny (yes, i hold a grudge against you for changing my username :D)
on another note
looks like i wont buy a car till end of the year :(
not rly man... not hilarious. just funny (yes, i hold a grudge against you for changing my username :D )
on another note
that should give you enough time to think of another billion types of cars you want to get :)
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
