they look nice but i cant see myself spending 4k for them though.
the tyres alone are worth over $1k easy, then brand new sp1s in that size it is a bargain when you think about it
but if you dont have the cash thats another thing haha
does anyone in here like to listen to classical music sometimes?
I did a few years ago when I was playing in an orchestra. Not much interest in it these days though..
phags :D
phags :D
haha, it shows class :D i have a folder of classical music that i sometimes listen to, it really helps you to chill and relax. ive got another folder with frank sinatra and dean martin lol. i like a huge range of music.
I only listen to it for study purposes :D Although there are a few classic pieces that are awesome. Like Orff's 'Carmina Burana'. EPIC.
http://www.youtube.com/watch?v=qF-Z0YPuabk
Edited by jezza boii
working on my car helps me to relax.... forget everything
i end up having my neighbours come over and say whats with all the yelling and swearing lol. and that's no joke its happened a couple times. one time i had the last bolt on the suspension that wouldnt come off i tried everything all it did was start to fall apart and i tried every trick, than after alot of yelling i grabbed the angle grinder and cut the Fu#ker off.
maybe ill listen to classical music next time im working on the car :D
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
