they look nice but i cant see myself spending 4k for them though.
the tyres alone are worth over $1k easy, then brand new sp1s in that size it is a bargain when you think about it
but if you dont have the cash thats another thing haha
does anyone in here like to listen to classical music sometimes?
I did a few years ago when I was playing in an orchestra. Not much interest in it these days though..
phags :D
phags :D
haha, it shows class :D i have a folder of classical music that i sometimes listen to, it really helps you to chill and relax. ive got another folder with frank sinatra and dean martin lol. i like a huge range of music.
I only listen to it for study purposes :D Although there are a few classic pieces that are awesome. Like Orff's 'Carmina Burana'. EPIC.
http://www.youtube.com/watch?v=qF-Z0YPuabk
Edited by jezza boii
working on my car helps me to relax.... forget everything
i end up having my neighbours come over and say whats with all the yelling and swearing lol. and that's no joke its happened a couple times. one time i had the last bolt on the suspension that wouldnt come off i tried everything all it did was start to fall apart and i tried every trick, than after alot of yelling i grabbed the angle grinder and cut the Fu#ker off.
maybe ill listen to classical music next time im working on the car :D
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
