HAHAHAHAHAHA ok ok i just got it... so sneaky, like "...007" wouldn't you say :happy:
I'd almost say 008 personally. Skylines make everything better.
Edited by jezza boii
if they wanna talk shit, there is wasteland. pics only in pics thread
hm... well it wasn't really called a pics only thread... if it was that's cool, but everyone was talking about the pics or subjects stemmed off the pics anyway.
We all know what a Skyline looks like and I see most of your cars either in your avatars or out on the road so the threads not much use without potential jabber imo.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
