No shit. Of course AWD is better, but I'd still take MR RWD over normal RWD. Personal preference of course though :)
And on another note... Am I slightly cooler now?
Edited by jezza boii
you must be blind... that's not flush. it's sunk in the back and poking in the front. and goddamn, get a wheel alignment and sus adjustment stat.
Okay, it's 2mm sunk. And 7mm poke at the front :) But it's much closer to flush than before.
Have booked in for a wheel alignment tomorrow morning. Will leave my car at work overnight.
jesus. you drove home like that? where'd you get the wheels n tyres fitted? they let you drive out like that?
I only drove back to my work, which is also in Dandenong.
The people that fitted the wheels aren't really tyre fitters. They just repair wheels. They helped me source tyres and did me a favor by fitting them for free.
Yeah, I hate the black strips. I'm getting them colour coded when the bodykit goes on :)
PS - Anyone know a good place to get my front guards flared? I don't want to get defected for my 7mm of poke.
bent suspension arms for superior traction when cornering left.
LOL :)
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
