Anyone here updated their iPhone (particularly 3G) to the new firmware and had problems with service?
3G running 4.0.1, no issues here. hella jailbroken n hax'd tho.
4.0.1 was fine, albeit slow on a 3G. updated to 4.0.2 and had no service when it rebooted, switched it off/on twice which did nothing...restored to original then restored from backup and it was fine...
looks like one of the first high performance imports mag's
for some reason got a really old feeling to it
haha interesting.
i just noticed how f**kin dodgy the M looks. right after handing it in. FML
also. just realised thomo kids are paying stupid prices for VS commos.... time to exploit this
fffuuu, the trailer wheels won't have gangster lean like the car with a solid axle. unless I get like IRS on the trailer. so CBF with that.
gonna look at building one of these with custom meisters... :D
alex, you can't use em unless you get chronic spacers and fender flares. 18"x11" +6 with 5x100 PCD
actually... fuck... with 11" wide wheels on either side that'll make the car tow dolly way too wide for road use. ah well, guess I'll just keep em as spares or put em on a regular trailer.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
