fark you, power only came on at like 4.30 in the morning so shitty night :ermm:
lol our power was off yesterday also! we had this letter come in the mail said it would be off between 8:30am - 4:30pm
was only off from around 9-1 - i was so bored since im home on crutches and nothing to do! lol
http://www.skylinesaustralia.com/forums/Vo...93#entry5407293
must...... NOT.......... BUY
:ermm: same specs as I just sold but mine were gold now that mine are gone I want them back :P
Opinions guys? I was planning on painting my 18x10 challenge fzeros matte black.. and get a new set of tyres but this is tempting.
:) same specs as I just sold but mine were gold now that mine are gone I want them back :(
i wouldnt get them, they look nice but thats way to expensive, the offset isnt good enough either :D
i dont know if its just me but i could never spend $4,500 on rims, even $3,000 is way to much lol.
here are some that are better and cheaper that i found lol. ( still to expensive for me though lol.)
http://www.importmonster.com.au/shop/produ...roducts_id=1004
http://www.importmonster.com.au/shop/produ...roducts_id=1037
http://www.importmonster.com.au/shop/produ...roducts_id=1066
i would be very close in buying these ones though:
http://cgi.ebay.com.au/WORK-WHEELS-XD9-SKY...rts_Accessories
i forgot to add, if anyone could help me out with this.
everyone says the stock boost gauges are crap so is it the same with an r34 gtr? i only ask because mine can peak to 1.18 which works out to be 15-16psi and i still have stock intake and exhaust on. my boost gauge reads a maximum of 1.2 so im right near the end of the gauge.
plus i blow out a bit of smoke on acceleration but im sure thats normal, its better to be running rich than lean.
comes with tyres tho.. tyres are like 400 a pop for decent ones..
those xd9s are f**king nice.. what you recon on a white 33 ?
i can show you, my mate just got them, ill ask him for a side on pic but here is the one he sent me the other day.
yeah we get a few letters like that
but this was something to do with either a short out or power pole down went off at like 9.30pm
Scott know what specs they are? I really want to get some hellaflush going.. figure if im going to do it want to do it properly got the coilovers.. now need some flushness and low
ill ask him what specs his rims are and get back to you as soon as i can.
in other news i should of gotten this kakimoto system lol, its very loud :)
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
